Results 1 to 23 of 23
  1. Member DuBsTaR's Avatar
    May 2007
    I believe the content is only available to Australia ? But am wondering if there is a way round to capture it at all ?
    http://www.mtv.com.au/shows/25th-aria-awards-2011/episodes/kylie-aria-interview/video/...erview-714423/
    Please can someone help me.
    Yep, it looks like that.
    You can use a proxy with an australia ip address, http://en.wikipedia.org/wiki/Proxy_server and then play/record with replay media catcher, streamtransport etc. But it's not that easy to find a free proxy that works though...
  3. Member DuBsTaR's Avatar
    May 2007
    Thanks Baldrick, I've tried, but no luck, I guess the video has to stream in order to get any kind of url right ? I've been trying to see whether there is any info within the page script but nothing
    Hopefully an Aussies will come to my rescue if there are any members from down under
  4. Originally Posted by Baldrick View Post
    Try proXPN: http://proxpn.com/
    Unlike HideMyIP (free for 14 days, then requires subscription), proXPN has a free option for life, but speed is limited (300kbps) and Miami, USA for IP address.
    I've only used proXPN a couple of times myself just to see if it worked.
  5. Member DuBsTaR's Avatar
    May 2007
    Try proXPN.
    http://proxpn.com/
    Unlike HideMyIP (free for 14 days, then requires subscription), proXPN has a free option for life, but speed is limited.
    Thanks very much, I'll have a look at it now
  6. Originally Posted by DuBsTaR View Post
    This probably wont help with capturing but you might also be interested in Hide My Ass:
    http://www.hidemyass.com/
    It is useful to know about.
    It works in your browser, and may enable you to watched blocked content in your country from certain sites.
  7. Member DuBsTaR's Avatar
    May 2007
    It works in your browser, and may enable you to watched blocked content on certain sites.
    I tried that, the video doesn't load unfortunately. I can't think of anything else to be honest.
  8. Originally Posted by DuBsTaR View Post
    Trial HideMyIP (14 days) or Easy Hide IP (3 days).
    http://www.hide-my-ip.com/
    http://www.easy-hide-ip.com/
    Failing that, someone may upload it to YouTube.
  9. Try RTMPDump
    rtmpdump.exe -r rtmpe://cp23054.edgefcs.net/ondemand/mtviestor/_!/intlod/au/mtvnews/extras/Kylie_IV_768x432_1700_m30.mp4 -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.10.7.swf" -o Kylie_IV_768x432_1700_m30.flv
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just so we are clear here....which of the PROXY products suggested to you have you downloaded and tried so far?
  11. Member bat999's Avatar
    Feb 2008
    Originally Posted by k. View Post
    Video won't play in UK but k's RTMPDump command works.
    Proxy not needed.
    Linux users have to escape ! with bash. Like this:-
    .../mtviestor/_\!/intlod/au/mtvnews/e...
  12. Member DuBsTaR's Avatar
    May 2007
    Thanks, how do I do that ?
    Open the programme and enter the above code into the RTM explorer ?
  13. Wow, it works even here in Canada
    @k. - How do you go about finding the correct command line ?
    @Dubstar - You just open up a command prompt and copy & paste the command line
    On XP, you start menu => run => type 'cmd' without the quotes and push enter => navigate to the directory with rtmpdump (with dos commands, you can use "cd" for change directory => enter command line
  14. Member DuBsTaR's Avatar
    May 2007
    Ok, I should mention I'm on Windows 7 now. I've tried what you said and it's 'unknown' command ?
    I get this
    RTMP Server 2.4 git-6230845 2011-9-25
    (c) 2010 Andrej Stepanchuk, Howard Chu; license: GPL
    Streaming on rtmp://0.0.0.0:1935
    Unknown command 'r', ignoring
    Unknown command 't', ignoring
    Unknown command 'm', ignoring
    Unknown command 'p', ignoring
    Unknown command 'd', ignoring
    Unknown command 'u', ignoring
    Unknown command '.', ignoring
    Unknown command 'e', ignoring
    Unknown command 'x', ignoring
    Unknown command ' ', ignoring
    Unknown command '-', ignoring
    Unknown command ':', ignoring
    Unknown command '/', ignoring
    Unknown command 'c', ignoring
    Unknown command '2', ignoring
    Unknown command '3', ignoring
    Unknown command '0', ignoring
    Unknown command '5', ignoring
    Unknown command '4', ignoring
    Unknown command 'g', ignoring
    Unknown command 'f', ignoring
    Unknown command 's', ignoring
    Unknown command 'n', ignoring
    Unknown command 'o', ignoring
    Unknown command 'a', ignoring
    Unknown command 'v', ignoring
    Unknown command 'i', ignoring
    Unknown command '_', ignoring
    Unknown command '!', ignoring
    Unknown command 'l', ignoring
    Unknown command 'w', ignoring
    Unknown command 'K', ignoring
    Unknown command 'y', ignoring
    Unknown command 'I', ignoring
    Unknown command 'V', ignoring
    Unknown command '7', ignoring
    Unknown command '6', ignoring
    Unknown command '8', ignoring
    Unknown command '1', ignoring
    Unknown command 'W', ignoring
    Unknown command '"', ignoring
    Unknown command 'h', ignoring
    Unknown command '
    ', ignoring
  15. the command prompt has to be in the right directory
    in win7 it's a bit easier, you hold shift and right click the folder where you want to go, "open command window here", so you are already in the correct folder
    see these screenshots
    http://www.windows7hacker.com/index.php/2009/08/how-to-open-dos-prompt-command-here-in...ws-7-and-more/
  16. Also, you probably don't have "quick edit" mode enabled
    This allows you do copy & paste whatever is in the clipboard into command prompt simply by right clicking
    http://www.winhelponline.com/blog/enable-quick-edit-command-prompt-by-default/
  17. Member DuBsTaR's Avatar
    May 2007
    Hi
    I'm lost what needs to be open, and the copy and past works fine, am just ignored errors
  18. Are you sure? I think if you right click copy & select paste without quick edit mode, each letter will be followed by a return (it will think each letter is a command, that's why you are getting those errors)
    It's better/easier than typing out the command line manually
  19. Member bat999's Avatar
    Feb 2008
    NO
    That's the wrong program.
    You need RTMPDump from here --> http://www.mediafire.com/?w8a69d8id4padac
  20. Member DuBsTaR's Avatar
    May 2007
    NO
    Yay it worked. Thanks guys
  21. Member bat999's Avatar
    Feb 2008
    [QUOTE=DuBsTaR;2124374]
    But why is Kylie yellow, has she been ill?
  22. Member DuBsTaR's Avatar
    May 2007
    [QUOTE=bat999;2124377]
    lol I've no idea.
  23. Member DuBsTaR's Avatar
    May 2007
    By the way, I forgot to mention, for future, how would I go about in getting the command line so I could use it again ? even if the content is unplayable [blocked] in the UK ?
