I am making timelapse films. I am using QuickTime Pro to export an image sequence as a movie file. I have all the images in a folder named numericaly. I go file>open image sequence click on the first image and import. The images are in the correct order in the source folder I have also checked the resource files under show movie properties and they are in the correct order there.
I then export as a QuickTime movie file at 1080p H.264 the film is stepping and the frames are out of sequence in the eported movie file.
Why is this? Has anyone come across this before?The frames are in the wrong order. Instead of 1,2,3,4,5,6..., pairs are swapped, 2,1,4,3,6,5. Every now and then (every 90 frames) there is another error in the order. A mostly fixed version is attached. Frames 65, 155, and 245 should still be swapped with the frames before them.
			Closed Thread
	One similar thread is enough, continue in https://forum.videohelp.com/threads/341066-Problems-with-turning-image-sequences-into-m...=1#post2123908 .
  Final Cut Pro, gives me GENERAL ERROR when exporting to QuicktimeBy Huntr777 in forum MacReplies: 8Last Post: 30th Sep 2011, 15:26
  quicktime pro will exporting to h.264 solve this huge file size issue?By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 22:43
  Exporting Premiere Pro to After Effects - WRONG in/out points!By Namie in forum EditingReplies: 5Last Post: 8th Feb 2010, 01:20
  Quicktime Problem: Playing and ExportingBy hzgg2 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2008, 16:48
  Problem exporting AVI to H.264 in Quicktime ProBy newsclips in forum Video ConversionReplies: 2Last Post: 31st May 2007, 01:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
