Page 2 of 2
FirstFirst 1 2
Results 31 to 33 of 33
  1. Originally Posted by jagabo View Post
    It's helpful if you say exactly what you did to solve your problem. That way someone else may benefit from this thread in the future.
    forgive me delay reply here my connection speed Morning to Midnight 50<kbps, after midnight only 2 0r 3 clock i can access faster..otherwise not working..
    Dear jagabo,
    you're mentioned Pro is the problem , then i uninstall QuickTime Alternative , install its fine working..
    Here I'm using not QT higher version pro,older version QT Pro working good, no crash..but some files not render bcoz already mention low version if i upgrade higher version system crash..
  2. Originally Posted by jagabo View Post
    Originally Posted by anbarasan View Post
    some files okay now mate..
    What does that mean? Is your problem solved?
    and please tell me what about my MEMTEST I already mention the post.
    It means your computer is having problems. You need to check the BIOS settings as Bjs indicated earlier. Or you may need to replace one of the memory sticks. The good news is that desktop memory is really cheap right now because of a global glut.
    yes bro BJS & yours both guide under I'm check my pc. before some post i mentioned the details & error..
    thanks again finally problem found & solution given thanks
  3. Actual reason is my memory problem..
    Gigabyte ,GA-VM900M System Specs
    Memory Type: DDR2 PC2-8500, DDR2 PC2-6400, DDR2 PC2-5300, DDR2 (non-ECC)
    Maximum Memory: 4GB
    Currently My system Installed Memory: 2GB
    Total Memory Slots: 2
    Available Memory Slots: 0
    SLOT 1:
    1GB
    DDR PC2-5200
    SLOT 2:
    1GB
    DDR PC2-5300
    removed 1GB DDR PC2 5200 , then working fine otherwise trouble.
