Results 1 to 30 of 33
  1. Hi friends
    Here I facing trouble QT Player crashes every time i try to play a video file .mov Look the attach image like video file few seconds freeze then auto reboot my system,or else shown QuickTime player has encounter a problem needs to close. when I install new QT version or old QT player same trouble image showing like happen every time. so
    completely uninstall again trying install fresh one, again same trouble. hmm so complete scan my system if may any spy,malware,virus hidden affect but nothing.XP formatted then trying fresh install same trouble.K-Lite & QT alternative VLC,GOM also tried not working . I hope here the right place to solve anything.
    friends can do me favor guide me.
    Thanks in advance
Name:	video error.JPG
  2. All mov files or one in particular?
  3. Member Cornucopia's Avatar
    My guess is it's either:
    A. A Mac-only codec trying to be playing in a Win machine (or vice-versa)
    or
    B. A corrupted/bogus file
    or
    C. A file created with such non-standard parameters that it "broke" the codec even though a file was created
    But it's hard to tell with such little info. Please, show us a MediaInfo output...
    Feb 2004
    Australia
    Welcome anbarasan
    To have XP display the error message instead of rebooting:
    1. Click Start, and then right-click My Computer.
    2. Click Properties.
    3. Click the Advanced tab, and then click Settings under Startup and Recovery.
    4. Under System failure, click to clear the Automatically restart check box.
    5. Click OK, and then click OK.
    Now try playback of offending file type which should trigger the restart but should now hang at bluescreen.
    Write the error down and post in next reply.
    Simply reboot the system from here to continue.
    Next:
    1: Run memtest, download the "Pre-Compiled Bootable ISO (.zip)" , unpack and burn the iso image to cd.
    2: Leave cd in system and reboot ... either F8 or F5 during bootup gives option to start system from optical drive.
    3: Do a general memory test ... if fail go to A.
    A: Shut system down, remove system power lead, then remove memory, clean contacts and memory slots.
    Rerun memtest.
    B: If passed, we'll need to see what files are involved which cause the system to reboot seeings how you've done a fresh reinstall of the operating system.
  5. Originally Posted by jagabo View Post
    Hearty thanks reply
    All .mov files
  6. Originally Posted by anbarasan View Post
    Hearty thanks reply
    All .mov files
    And only mov files? That would be very odd because VLC uses internal readers, splitters, and codecs for all video containers and codecs. Only the rendering device (graphics card) is common between VLC and other players. So if VLC is screwing up it must be the rendering device. But the same rendering device would be used regardless of the file type being played. Just as a test, in VLC select: Tools -> Preferences -> Video. In the Display box try setting the Output device to Windows GDI Video Output. Exit and restart VLC. Is there any improvement?
  7. Originally Posted by Cornucopia View Post
    or
    or
    Hearty thanks for u , here the info .mov sample which I'm playing problem occur.
    General
    Count                            : 278
    Count of stream of this kind     : 1
    Kind of stream                   : General
    Stream identifier                : 0
    Inform                           : Count                            : 278
    StreamCount                      : 1
    StreamKind                       : General
    StreamKind/String                : General
    StreamKindID                     : 0
    StreamCount                      : 1
    StreamKindID                     : 0
    Inform                           : QuickTime: 1.62 MiB, 5mn 20s
    VideoCount                       : 1
    AudioCount                       : 1
    Video_Format_List                : smc
    Video_Format_WithHint_List       : smc
    Video_Codec_List                 : SMC
    Video_Language_List              : English
    Audio_Format_List                : AAC
    Audio_Format_WithHint_List       : AAC
    Audio_Codec_List                 : AAC LC
    Audio_Language_List              : English
    CompleteName                     : C:\Learn\0102.mov
    FolderName                       : C:\Learn
    FileName                         : 0102
    FileExtension                    : mov
    Format                           : QuickTime
    Format/String                    : QuickTime
    Format/Info                      : Original Apple specifications
    Format/Url                       : http://www.apple.com/quicktime/download/standalone.html
    Format/Extensions                : mov qt
    Format_Commercial                : QuickTime
    Format_Settings                  : Compressed header
    InternetMediaType                : video/quicktime
    Codec                            : QuickTime
    Codec/String                     : QuickTime
    Codec/Info                       : Original Apple specifications
    Codec/Url                        : http://www.apple.com/quicktime/download/standalone.html
    Codec/Extensions                 : mov qt
    Codec_Settings                   : Compressed header
    FileSize                         : 1703281
    FileSize/String                  : 1.62 MiB
    FileSize/String1                 : 2 MiB
    FileSize/String2                 : 1.6 MiB
    FileSize/String3                 : 1.62 MiB
    FileSize/String4                 : 1.624 MiB
    Duration                         : 320600
    Duration/String                  : 5mn 20s
    Duration/String1                 : 5mn 20s 600ms
    Duration/String2                 : 5mn 20s
    Duration/String3                 : 00:05:20.600
    OverallBitRate                   : 42502
    OverallBitRate/String            : 42.5 Kbps
    StreamSize                       : 24028
    StreamSize/String                : 23.5 KiB (1%)
    StreamSize/String1               : 23 KiB
    StreamSize/String2               : 23 KiB
    StreamSize/String3               : 23.5 KiB
    StreamSize/String4               : 23.46 KiB
    StreamSize/String5               : 23.5 KiB (1%)
    StreamSize_Proportion            : 0.01411
    HeaderSize                       : 81301
    DataSize                         : 1679277
    FooterSize                       : 18446744073709494319
    IsStreamable                     : Yes
    Encoded_Date                     : UTC 2004-02-20 15:57:47
    Tagged_Date                      : UTC 2004-02-20 15:57:48
    File_Created_Date                : UTC 2011-12-01 02:20:03.930
    File_Created_Date_Local          : 2011-12-01 07:50:03.930
    File_Modified_Date               : UTC 2006-10-15 12:02:50.000
    File_Modified_Date_Local         : 2006-10-15 17:32:50.000
    Encoded_Library                  : Apple QuickTime
    Encoded_Library/String           : Apple QuickTime
    Encoded_Library/Name             : Apple QuickTime
    Copyright                        : 1996-2004
    VideoCount                       : 1
    AudioCount                       : 1
    FileName                         : 0102
    FileExtension                    : mov
    Format                           : QuickTime
    Codec                            : QuickTime
    FileSize                         : 1703281
    Duration                         : 320600
    StreamSize                       : 24028
    HeaderSize                       : 81301
    DataSize                         : 1679277
    IsStreamable                     : Yes
    Count of video streams           : 1
    Count of audio streams           : 1
    Codecs Video                     : SMC
    Audio codecs                     : AAC LC
    Complete name                    : C:\Learn\0102.mov
    Folder name                      : C:\Learn
    File name                        : 0102
    File extension                   : mov
    Format                           : QuickTime
    Format                           : QuickTime
    Format/Extensions usually used   : mov qt
    Commercial name                  : QuickTime
    Format settings                  : Compressed header
    Internet media type              : video/quicktime
    Codec                            : QuickTime
    Codec                            : QuickTime
    Codec/Extensions usually used    : mov qt
    Codec settings                   : Compressed header
    File size                        : 1703281
    File size                        : 1.62 MiB
    File size                        : 2 MiB
    File size                        : 1.6 MiB
    File size                        : 1.624 MiB
    Duration                         : 320600
    Duration                         : 5mn 20s
    Duration                         : 5mn 20s 600ms
    Duration                         : 5mn 20s
    Duration                         : 00:05:20.600
    Overall bit rate                 : 42502
    Overall bit rate                 : 42.5 Kbps
    Stream size                      : 24028
    Stream size                      : 23.5 KiB (1%)
    Stream size                      : 23 KiB
    Stream size                      : 23.46 KiB
    Proportion of this stream        : 0.01411
    HeaderSize                       : 81301
    DataSize                         : 1679277
    IsStreamable                     : Yes
    Encoded date                     : UTC 2004-02-20 15:57:47
    Tagged date                      : UTC 2004-02-20 15:57:48
    File creation date               : UTC 2011-12-01 02:20:03.930
    File creation date (local)       : 2011-12-01 07:50:03.930
    File last modification date      : UTC 2006-10-15 12:02:50.000
    File last modification date (loc : 2006-10-15 17:32:50.000
    Writing library                  : Apple QuickTime
    Writing library/Name             : Apple QuickTime
    Video
    Count                            : 205
    Kind of stream                   : Video
    Inform                           : Count                            : 205
    StreamCount                      : 1
    StreamKind                       : Video
    StreamKind/String                : Video
    StreamKindID                     : 0
    Inform                           : English, 9 906 bps, 640*480 (4:3), at 3.000 fps, smc
    ID/String                        : 1
    Format                           : smc
    Format_Commercial                : smc
    CodecID                          : smc
    Codec                            : smc
    Codec/String                     : SMC
    Codec/Info                       : Apple Graphics (SMC)
    Codec/CC                         : smc
    Duration                         : 320600
    Duration_LastFrame               : -67
    Duration_LastFrame/String        : -67ms
    Duration_LastFrame/String1       : -67ms
    Duration_LastFrame/String2       : -67ms
    Duration_LastFrame/String3       : -00:00:00.067
    BitRate                          : 9906
    BitRate/String                   : 9 906 bps
    Width                            : 640
    Width/String                     : 640 pixels
    Height                           : 480
    Height/String                    : 480 pixels
    PixelAspectRatio                 : 1.000
    DisplayAspectRatio               : 1.333
    DisplayAspectRatio/String        : 4:3
    Rotation                         : 0.000
    FrameRate_Mode                   : CFR
    FrameRate_Mode/String            : Constant
    FrameRate                        : 3.000
    FrameRate/String                 : 3.000 fps
    FrameCount                       : 962
    Bits-(Pixel*Frame)               : 0.011
    StreamSize                       : 397071
    StreamSize/String                : 388 KiB (23%)
    StreamSize/String1               : 388 KiB
    StreamSize/String2               : 388 KiB
    StreamSize/String3               : 388 KiB
    StreamSize/String4               : 387.8 KiB
    StreamSize/String5               : 388 KiB (23%)
    StreamSize_Proportion            : 0.23312
    Language                         : en
    Language/String                  : English
    Language/String1                 : English
    Language/String2                 : en
    Language/String3                 : eng
    Language/String4                 : en
    Encoded_Date                     : UTC 2004-02-20 15:50:51
    Format                           : smc
    Commercial name                  : smc
    Codec ID                         : smc
    Codec                            : smc
    Codec                            : SMC
    Codec/CC                         : smc
    Duration                         : 320600
    Duration                         : 5mn 20s
    Duration                         : 5mn 20s
    Duration_LastFrame               : -67ms
    Duration_LastFrame               : -00:00:00.067
    Bit rate                         : 9906
    Bit rate                         : 9 906 bps
    Width                            : 640
    Width                            : 640 pixels
    Height                           : 480
    Height                           : 480 pixels
    Pixel aspect ratio               : 1.000
    Display aspect ratio             : 1.333
    Display aspect ratio             : 4:3
    Rotation                         : 0.000
    Frame rate mode                  : CFR
    Frame rate mode                  : Constant
    Frame rate                       : 3.000
    Frame rate                       : 3.000 fps
    Frame count                      : 962
    Bits/(Pixel*Frame)               : 0.011
    Stream size                      : 397071
    Stream size                      : 388 KiB (23%)
    Stream size                      : 387.8 KiB
    Proportion of this stream        : 0.23312
    Language                         : en
    Language                         : English
    Language                         : English
    Language                         : en
    Language                         : eng
    Language                         : en
    Encoded date                     : UTC 2004-02-20 15:50:51
    Audio
    Count                            : 173
    Kind of stream                   : Audio
    Inform                           : Count                            : 173
    StreamCount                      : 1
    StreamKind                       : Audio
    StreamKind/String                : Audio
    StreamKindID                     : 0
    Inform                           : English, 32.0 Kbps, 22.05 KHz, 1 channel, AAC (LC)
    ID/String                        : 2
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format_Commercial                : AAC
    Format_Profile                   : LC
    CodecID                          : 40
    Codec                            : AAC LC
    Codec/String                     : AAC LC
    Codec/Family                     : AAC
    Codec/CC                         : 40
    Duration                         : 320573
    Duration/String1                 : 5mn 20s 573ms
    Duration/String3                 : 00:05:20.573
    BitRate_Mode                     : CBR
    BitRate_Mode/String              : Constant
    BitRate                          : 32000
    BitRate/String                   : 32.0 Kbps
    Channel(s)                       : 1
    Channel(s)/String                : 1 channel
    ChannelPositions                 : Front: C
    ChannelPositions/String2         : 1/0/0
    SamplingRate                     : 22050
    SamplingRate/String              : 22.05 KHz
    SamplingCount                    : 7068635
    Compression_Mode                 : Lossy
    Compression_Mode/String          : Lossy
    StreamSize                       : 1282182
    StreamSize/String                : 1.22 MiB (75%)
    StreamSize/String1               : 1 MiB
    StreamSize/String2               : 1.2 MiB
    StreamSize/String3               : 1.22 MiB
    StreamSize/String4               : 1.223 MiB
    StreamSize/String5               : 1.22 MiB (75%)
    StreamSize_Proportion            : 0.75277
    Language                         : en
    Encoded_Date                     : UTC 2004-02-20 15:50:52
    Format                           : AAC
    Commercial name                  : AAC
    Format profile                   : LC
    Codec ID                         : 40
    Codec                            : AAC LC
    Codec                            : AAC LC
    Codec/Family                     : AAC
    Codec/CC                         : 40
    Duration                         : 320573
    Duration                         : 5mn 20s
    Duration                         : 5mn 20s 573ms
    Duration                         : 5mn 20s
    Duration                         : 00:05:20.573
    Bit rate mode                    : CBR
    Bit rate mode                    : Constant
    Bit rate                         : 32000
    Bit rate                         : 32.0 Kbps
    Channel(s)                       : 1
    Channel(s)                       : 1 channel
    Channel positions                : Front: C
    Channel positions                : 1/0/0
    Sampling rate                    : 22050
    Sampling rate                    : 22.05 KHz
    Samples count                    : 7068635
    Compression mode                 : Lossy
    Stream size                      : 1282182
    Stream size                      : 1.22 MiB (75%)
    Stream size                      : 1 MiB
    Stream size                      : 1.2 MiB
    Stream size                      : 1.223 MiB
    Proportion of this stream        : 0.75277
    Language                         : en
    Language                         : English
    Language                         : English
    Language                         : en
    Language                         : eng
    Language                         : en
    Encoded date                     : UTC 2004-02-20 15:50:52
  8. Originally Posted by jagabo View Post
    Hearty thanks reply
    All .mov files
    VLC changes after I can hear audio only, video just black screen only.
  9. Probably no, or bad, SMC support under Windows.
    Secure Managed Client ? XP
  11. Originally Posted by Bjs View Post
    Welcome anbarasan
    Next:
    Rerun memtest.
    Hearty Thanks
    Morning 9.00am (GMT+5.30) I'm started your guide above info steps.Bios change the priority Booting
    1st Boot CD/DVD
    2nd Boot HDD
    Then reboot Pc automatically Move the memtest started.
    Pentium E1206MHZ
    L1 Cache: 32K 16748 MB/s
    L2 Cache: 1024k 7881 MB/s
    L3 Cache: none
    Memory: 1984M 2310MB/s
    Chipset:
    Wall Time || cached || RSVDmem || memmap || cache || Ecc || Test || pass || Errors || EccErrors
    2:15:52 || 1984M || 12K || e820 || on || off || std || 1 || 14 || 0
    Error Report
    TST || Pass || Failing Address || Good || Bad || Err-Bits || Count || Chan
    4 || 0 || 0001C40589C -452.0MB ||e9d883da || ebd883da || 020000000 || 1 ||0
    When "WallTime 7:18:52, Errors 96" but error report only one shown above same. Here power failure before memtest noted info this.. Need to started again or change any Configuration Memtest.
    Please tell me.
    im little upset friend
  13. qtpro on windows plays the smc samples linked on that webpage fine on this pc
    maybe your files are corrupted? can you upload a sample ?
  14. Originally Posted by poisondeathray View Post
    I think "pro" is the issue.
  15. Currently my Wireless modem going down speed 70Kbps, i unable to upload/download file sorry poisondeathray.
  16. sorry forgot say about my PC details little, Here ,
    Processor Specification:Intel(R)Pentium(R) Dual core @1.60GHz
    Name:Intel Pentium E2140,Code Name:Conroe,packageocket 775 LGA
    Mainboard:Gigabyte ,Model VM900M
    Graphic interface: AGP version 3.0
    Graphics GPU name: VIA Chrome9 HC IGP
    Memory DDR2 Size 2GB
    Dram frequency:335.0Mhz
    HDD1 IDE 80GB
    HDD2 Sata 120GB
    Windows XP Professioanl SP3
  17. Honestech TVR software crashes my computer now, before quicktime problem now this TVR SW. when i play Honestech TVR software above image like full monitor shown and sudden reboot, cable TV wire with/without connect after also same trouble.
    My Card Details:
    Type: internal
    Item name: Intex TV Tuner Card W/O Fm IT-TV7130
    Please can anybody do favor.
    thanks in advance both problem giving advise
  18. The card came with Honestech TVR software for capturing and watching TV. But the program keeps crashing. After a couple of minutes of TV viewing I get an error message. Also, when I record something and I press play it crashes immediately. before not happen this same software but right now nothing.
  19. Originally Posted by jagabo View Post
    pro is the problem ?
  20. Originally Posted by anbarasan View Post
    I only saw Quicktime Alternative mentioned in your first post. I was guessing that meant you didn't have Quicktime Pro -- which you have to pay for. I believe Quicktime Pro includes more codecs.
  21. Originally Posted by jagabo View Post
    thank u
  22. Member
    Feb 2004
    Australia
    Try the following to test system.
    1: Remove mem from slot 0 and leave it out of the system ... take mem from slot 1 and install into mem slot 0
    2: Remove that capture card for now
    3: In bios make sure memory timing is set to 200mhz ... never auto
    Download and run filmerit ... are there any errors in filters ?
    From here we should get close to what is likely the cause of the problem.
    From here test mov in vlc first, then again in quicktime ...
  23. Originally Posted by Bjs View Post
    The memory errors are a problem. But not the cause of his playback issues. VLC does not include an Apple SMC decoder.
  24. Member Cornucopia's Avatar
    an easy test would be to take one or more of your files and test them on a different, known-good QT-playing machine. If they're small, you can post here...
  25. Originally Posted by Bjs View Post
    Thank you BJS here attached the details please download the zip file
    Number of filters = 300
    Number of errors = 13
    and please tell me what about my MEMTEST I already mention the post.
  26. Originally Posted by Cornucopia View Post
    some files okay now mate..
  27. Originally Posted by anbarasan View Post
    What does that mean? Is your problem solved?
    It means your computer is having problems. You need to check the BIOS settings as Bjs indicated earlier. Or you may need to replace one of the memory sticks. The good news is that desktop memory is really cheap right now because of a global glut.
  28. 80% of yours all suggestion solve my trouble friends, its okay, yeah BJS indicated earlier steps working ,I'm not replace my memory sticks.
  29. It's helpful if you say exactly what you did to solve your problem. That way someone else may benefit from this thread in the future.
