Hi guys just a small quick question here , i havent been using this program for a great amount of time but been messing around, Because i like to make dvds with a few films on the one disc i obviously need to lower bitrate to around 2000 so the quality is ok but not great.
Question is whats better for a low bitrate movie , the sharpen line in avs script or msharpen? and what value do you think would be best for a low bitrate darker movie?
Or does anyone think any of the other things i can add to avisynth script will give a better picture like hqdn3d and so on?
Cheers!
If you are looking for improvement on darker areas, you should play with HCenc LUMGAIN feature. Go to 'Edit Title'/'Video', toggle off 'Auto Video Setup', click on 'HCenc Advanced Option' and increase LUMGAIN. Use a step-wise approach.
Sharpen can help with low bitrates, but may increase artifacts. MSharpen is less invasive than Sharpen, very useful with anime. Hqdn3d removes noise, very handy with DV video captures.
Bye -
Sharpening the picture increases the bitrate requirement. msharpen will be better than sharpen. The latter will increase noise as well as sharpen edges. Strong spacial and temporal filtering reduces the bitrate requirement but can also produce posterization artifacts (especially in dark areas) and makes everything look like plastic. There are custom matrices optimized for low bitrate encoding.
How to use sharpen filters with Avisynth & MeGUI??
By jeticson in forum DVD RippingReplies: 10Last Post: 28th Aug 2011, 09:40 -
Is there a relatively simple program to sharpen up a VHS capture?
By Prynter in forum RestorationReplies: 4Last Post: 18th Jun 2010, 14:35 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 08:29 -
sharpen your video
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 00:57 -
How can I enhance / sharpen this video?
By ferrous in forum RestorationReplies: 2Last Post: 22nd May 2007, 17:10
