Hello,
I am getting unreadable disk errors on my Philips 5-disk DVD changer. The disks play fine on other players. I have checked the spindle and laser head motors and the laser is turning on.
I would like to calibrate the laser, does anyone know how or where I could find the information?
Thank You
Does anyone smoke in your house?
Try cleaning the laser lense with some Windex like cleaner.
Also, you can't calibrate the laser.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Yeah, lasers on a CD/DVD/BD drive are rarely even accessible, let alone allowing end-user adjustment. The way a FACTORY or REPAIR SHOP would "re-calibrate" a laser has to do with getting an optimal signal reflection WHEN appropriate. One needs specialized tools to do that (specially encoded test discs + guidebooks, mounting/alignment adjustment tools, oscilloscopes,...)
Other than cleaning a laser+sensor housing - with brush-disc (not so good) or Q-tip swab (only slightly better) - there is NOTHING a consumer can or SHOULD do with this part of one's equipment.
Scott -
bteddy - Your player came out 10 years ago. They don't last forever. If you can't live without it then pay what it will cost for Philips to fix it, but it won't be cheap.
Google it, I found several sites on how to callibrate a dvd player laser, but do at your own risk!
Laser Disc to VHS to DVD
By Clevo89 in forum Capturing and VCRReplies: 12Last Post: 5th May 2010, 08:57 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Don't forget to clean your dvd drives laser lens!
By freebird73717 in forum DVD RippingReplies: 2Last Post: 1st Feb 2008, 09:57 -
Toshiba: first setop that burns high-def to red-laser DVD
By TheResonator in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Oct 2007, 11:33 -
Fixing a DVD recorder by re-aligning the laser/lense focus?
By D'oh! in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th May 2007, 23:14
