My goal: Create a slideshow (VCD 2.0 format) using hi-res MPEG Stills. 3 MPEG stills, each with a soundtrack. Show each one for 30 seconds (or till end of soundtrack), then loop to the beginning, forever. If VCD is started with PBC off, display a warning (mpeg stream) to turn PBC on.
I *thought* I had finally nicked the problem. Using the following guide: http://www.geocities.com/mikk999/StillsWithAudio.htm and every tool known to man I created the following XML (will attach at the end) to do just that. It works (though a bit erratically, screen keeps resizing) in Signio's software VCD player. But burning it to a VCD, I only get sound at best. Garbled sound at worst. Tested on 2 hardware VCD players so far. Anyone have any ideas??
HELP!!! :-)Code:<?xml version="1.0"?> <!DOCTYPE videocd PUBLIC "-//GNU//DTD VideoCD//EN" "http://www.gnu.org/software/vcdimager/videocd.dtd"> <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="vcd" version="2.0"> <!-- <option name="relaxed aps" value="false"/> <option name="track pregap" value="600"/> <option name="track front margin" value="600"/> <option name="track rear margin" value="45"/> <option name="leadout pregap" value="300"/> --> <info> <album-id>VIDEOCD</album-id> <volume-count>1</volume-count> <volume-number>1</volume-number> <restriction>0</restriction> </info> <pvd> <volume-id>VIDEOCD</volume-id> <system-id>CD-RTOS CD-BRIDGE</system-id> <application-id>CDI/CDI_VCD.APP;1</application-id> <preparer-id>Alex</preparer-id> <publisher-id>1.12</publisher-id> </pvd> <filesystem> <folder> <name>CDI</name> <file src="cdi/cdi_vcd.app"> <name>CDI_VCD.APP</name> </file> <file src="cdi/cdi_vcd.cfg"> <name>CDI_VCD.CFG</name> </file> <file src="cdi/cdi_text.fnt"> <name>CDI_TEXT.FNT</name> </file> <file src="cdi/cdi_imag.rtf" format="mixed"> <name>CDI_IMAG.RTF</name> </file> </folder> <!-- <file src="C:\Documents and Settings\Administrator\Desktop\VCD_PLAY.EXE"> <name>VCD_PLAY.EXE</name> </file> <file src="C:\Documents and Settings\Administrator\Desktop\Downloads\icons\FOOD\Beer3.ico"> <name>BEER3.ICO</name> </file> <file src="C:\Documents and Settings\Administrator\Desktop\Downloads\icons\FOOD\autostart.inf"> <name>AUTOSTART.INF</name> </file> --> </filesystem> <segment-items> <segment-item src="C:\Documents and Settings\Administrator\My Documents\Tajaumas\pbc.mpg" id="nopbc"/> </segment-items> <sequence-items> <sequence-item src="C:\Documents and Settings\Administrator\My Documents\Tajaumas\tajaum~1.mms" id="menu-0"/> <sequence-item src="C:\Documents and Settings\Administrator\My Documents\Tajaumas\MENU1.MMD" id="music-0"/> <sequence-item src="C:\Documents and Settings\Administrator\My Documents\Tajaumas\tajaum~2.mms" id="menu-1"/> <sequence-item src="C:\Documents and Settings\Administrator\My Documents\Tajaumas\MENU2.MMD" id="music-1"/> <sequence-item src="C:\Documents and Settings\Administrator\My Documents\Tajaumas\tajaum~3.mms" id="menu-2"/> <sequence-item src="C:\Documents and Settings\Administrator\My Documents\Tajaumas\MENU3.MMD" id="music-2"/> </sequence-items> <pbc> <playlist id="playlist-00" rejected="false"> <next ref="playlist-01"/> <return ref="playlist-00"/> <playtime>30</playtime> <wait>1</wait> <play-item ref="menu-0"/> <play-item ref="music-0"/> </playlist> <playlist id="playlist-01" rejected="false"> <next ref="playlist-02"/> <return ref="playlist-01"/> <playtime>30</playtime> <wait>1</wait> <play-item ref="menu-1"/> <play-item ref="music-1"/> </playlist> <playlist id="playlist-02" rejected="false"> <next ref="playlist-00"/> <return ref="playlist-00"/> <playtime>30</playtime> <wait>1</wait> <play-item ref="menu-2"/> <play-item ref="music-2"/> </playlist> </pbc> </videocd>
Results 1 to 1 of 1
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 03:40 -
Making an interesting start to a slide show
By avz10 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2010, 23:57 -
How to Create Advanced Menu Buttons?
By deftones_mrbungle in forum Authoring (DVD)Replies: 1Last Post: 12th Jan 2009, 16:43 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 07:27 -
best Super settings for slide show playback
By alldigitalsupport in forum Video Streaming DownloadingReplies: 0Last Post: 23rd Apr 2008, 12:21
