Closed Thread
Results 31 to 46 of 46
64 bit programs require 64 bit codecs. You have to download and install a 64 bit build of ffdshow:
https://www.videohelp.com/download/ffdshow_rev4052_20111120_clsid_x64.exe
After installation it will show up under Start -> All Programs -> ffdshow x64 -> Video Decoder Configuration.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
well it seems I did have 64 bit of ffdshow for win xp but wmv3 codec isn't working still
Natty(theNutter),
WinXP 64 was little more than a successful 64bit experiment. I'd highly recommend going to Win7 64bit if you want to stay in the Win64 environment.
On a side note:
GO TO THE THEATER TO SEE THE F*CKING MOVIE!!!!
Sorry, I feel better now. With all due respect, I recommend fully installing each the following codec packs:
K-Lite
CCCP
Win7codecs
XP Codec Pack
A link to each can be found in the tools section on this site. Once installed one or more should clear up any codec issues you may have.
Happy Holidays!
Have a good one,
neomaine
WTF do you think you are calling me Natty(theNutter) Im sure you are not innocent yourself and have downloaded illegal copys. so dont go calling me names ok FH. I'm 95% convinced most on here have done it sometime or another come on man get real. what you a saint then Hmmm don't think so somehow
And here I am actually trying to help you out.... Nice. Install the codec packs and be done with it.
Have a good one,
neomaine
Just the screener thing. I'm over it now ... don't worry about. Usually just a couple of the codec packs will do but shouldn't be a problem if you use all four.
Have a good one,
neomaine
yes I enabled those settings on the ffdshow config for 64 bitDid you enable the decoders in the 64 bit version?
You know, it's always helpful when you provide more information, not less.
Thanks, so can you use all 4 of those codecs then on xpJust the screener thing. I'm over it now ... don't worry about. Usually just a couple of the codec packs will do but shouldn't be a problem if you use all four.
Have a good one,
neomaine
please recommend movie codecs for XP/WMP11
By JohnnyBob in forum Software PlayingReplies: 3Last Post: 15th Aug 2011, 03:57 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 15:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52 -
Movie Maker Codecs?
By xiaofan in forum EditingReplies: 35Last Post: 26th Jun 2007, 23:48
