Jagabo, I was surprised to find that DeFlick had a good effect on some of that left-hand junk. There's such a flood of temporal noise in this clip, it often fills the whole frame -- when that happens, is it possible that such a flood of smudgy junk looks like"flicker" to Deflick (???) for a frame or two? Whatever. But, no, it's not the flicker that antiflicker filters are built for, and Deflick certainly didn't fix the whole frame.
Holygamer: heavy grain, streaks, smudges, etc., dance around rapidly in a moving image. But that's not flicker.
Results 91 to 120 of 280
What script are you using? The script and the attached .zip file I posted yesterday in post #63 is exactly what I used for the posted MPEG.
https://forum.videohelp.com/threads/341188-Still-have-flicker-after-Denoising-with-AviS...=1#post2125290
There's no missing element in the script. It uses ColorYUV, chubbyrain2, FixChromaBleeding, Deflick, and Neat Video, in that order. You apparently don't have Neat Video on your system. The script won't run without it. That's why I've been looking for a replacement that uses spatial/temporal filters with motion compensation and works in YCbCr. That's what Neat Video does. The script does a lot of work and runs for about 20 minutes.
IF you don't have Neat Video or the filter setting files, don't you get errors when you run that script?Last edited by sanlyn; 21st Mar 2014 at 07:49.
Yes, holygamer, it does get frustrating when you first get into video work. And after you've been in it a while, as well. First, though, you say the script did everything you wanted (and more), then you ask "what part of it" does what you wanted. You have a damaged tape, bad dupes, a tsunami of noise, but the script fixed almost all of it without too many side effects. That's the point: you have the filters and a script that accomplished what you wanted.
If you mean you want a one-line command that says something like "fix this()" and runs in 10 seconds, it doesn't exist. The scripts you've been looking at aren't massive (MCTemporalDenoise is a bit long, and it can literally run for days). I'd suggest it takes time and some patience to find your way around video problems, as with any project. You might try submitting a troubled video to a restoral shop and see how it goes. But with many of those shops (not all), you might be disappointed.Last edited by sanlyn; 21st Mar 2014 at 07:49.
Jagabo, you're correct. Sorry about before, I was just frustrated.
Sanlyn, your script works fine. It's just that it takes way too long. I'll propably use it on a rainy day when I've got time to spare but right now I've got to get my videos done before Christmas.
On my other videos which are about 4.2 Mbps, I used the below script but found that I get blocking which doesn't appear in the video until it is processed into an M2V by HC Encoder. I increased the bitrate to the maximum allowed in the DVD spec of 9.8 Mbps and that got rid of it. However I tried 9.5 Mbps and there was still some blocking. So I'm concerned that my videos which have a lower bitrate than 4.2 Mbps might still have blocking when processed into a 9.8 Mbps video.
If I process the video again with CPU=6 that removes the blocking but I obviously don't want to process the file again as you lose quality. Is there any decent fast Deblocker I could use which actually does what it's supposed to do?
I also tried saving my video as M2TS h264 and that gets rid of all the blocking, even the fine blocks and it looks brialliant. DeBlock is supposed to use the deblocking filter of h264 but that doesn't seem to be true as I still have blocking after using it!
ttempsmoothF(maxr=3, lthresh=8, cthresh=5, strength=4, interlaced=true)
There aren't any "fast" filters for video that has problems as severe as this one. I've worked with worse, but it's still kinda messy.
Can't answer for HC encoder, I don't use it. But I know it's competent stuff. Other members are more familiar with it.
I've used several deblockers. Most are designed for anime. They're all slow.Last edited by sanlyn; 21st Mar 2014 at 07:49.
Yes, Donald Graft's Deflicker filter for VirtualDub includes a temporal smoother in addition to the deflicker function. Just as with any temporal smoother you will get motion artifacts if you turn it up too high.
I'll try playing with DeFlick's settings. Yours were good tips in this thread on the settings, I always had trouble with it before.
Slow filters: I set them up before beddy-bye and let them run overnight. Works wonders.
I find it hard to believe you could see a significant difference in blocking between 9.8 and 9.5 Mb/s encodings. And minor blocking isn't noticeable at normal playback speeds. All DVDs have a bit of it.
The bitrate of the original recording doesn't directly influence the amount bitrate you will need after filtering. What matters is how much noise, motion, flicker, etc. exists after filtering.
I don't understand this question. MSU Deblocking does what it's supposed to do. Mpeg2Source's deblocker does what it's supposed to do. Deblock() does what it's supposed to do. Deblock_qed() does what it's supposed to do. A deblocking filter can only have an effect on the video fed into it. It cannot have any affect on blocking artifacts created by later encoding with too little bitrate.
h.264 has deblocking built into the decoder. MPEG 2 does not (Mpeg2Source being an exception). -
What I'm saying is that I feed the same video into M2TS h264 that I feed into an MPEG 2 with DeBlock. H264 removes the blocking without making the picture look horrible but DeBlock does not remove the blocking unless I use strong settings but then it makes the picture look horrible. DeBlock is supposed to use the deblocking filter of h264 yet it doesn't seem to have the same effect as encoding the video in H264.
TMPGenc Plus 2.5 most of the time (strictly for SD), has great color correction filters. Or sometimes, CCE. Inevitably, I have to move on to HD soon. But every year, all the Christmas projects keep slowing me down.
I have a question about deflicker: How do you remove the sudden "flash" in scene changes? It's a great filter, but this is the only thing that keeps me from really using it.
what number would completely eliminate it, and would it affect the filtering
dumb question: of COURSE it would affect the filtering. What I meant was, HOW would completely eliminating it affect the filtering?
What scene change threshold you use will depend how much the video flickers. Try values from about 5 to 20. Deflickering will still work on the rest of the video. If you lower the scene change threshold too much flicker will start to look like scene changes and deflickering will become ineffective.
Got it. I'll toy around with this when I get home. Thanks. Oh one more thing, Denoise (by the "fIsh") is based on deflicker. It seems to work well in conjunction with Neat Video (settings between 6-9 work best). Another good denoiser is NDR (by Sergey) - also called Suppressor of the Noise. Works well with Neat video as well. The thing with Neat, as Sanlyn stated previously, is that it NEEDS to work with another denoiser. It's temporal settings are weak and allow artifacts to slip through. The chroma smoothing is excellent though, if used at the right settings and if a proper profile is built.
I've cleaned up many temporal problems (certainly not everything, of course) with Neat Video's temporal filter, but it's nearly useless with flickering objects. Doesn't do anything for spots, either. But it's not designed for that. As unclescoob states, NV does work "better" overall in conjunction with other AviSynth filters. Depends on what you're trying to fix, and lots of fiddling required -- but, then, when is it not required, regardless of the filters(s) used.?
Sanlyn, let me get this straight, and if I'm right...it's a HUGE coincidence because I've been discovering the same thing lately:
What you're saying is that first you do some "prepping" (as I call it) in Avisynth with heavy flickered/grainy video before sending it to Virtualdub and adding NeatVideo? Before I get into details, let me know if I'm assuming correct. I'll be back to the thread late tonight. This is very interesting. If this is the case, we definitely need to talk. -
I can't add any more to that process than describe it in general terms. There's much experimentation, and it depends on the kind of noise. Neat Video has no problem with grain (in fact you have to cut NV down a bit or it will over-clean), but mostly I use a motion-compensated plugin or a deflicker or de-spotter. I don't know many AviSynth degrainers that won't overly soften the whole image. That's about all I can describe. I keep tweaking the plugins, and if they don't clean up 100% I add NeatVideo (not always). Sometimes, NV is all I need. It depends on what I'm trying to clean. And it's not 100% sure-fire.
Neat Video isn't designed for spot or flicker removal. You will need to remove those separately.
Ok, so for example (and yes, I'm going to post a sample, but it's late now so perhaps tomorrow) I have this particular episode with HEAVY flickering in some scenes due to a substantial amount of noise.
So what I did was first load it into avisynth and use the Temporal Cleaner at reasonable settings in order to suppress some of that stuff (but not get rid of the noise entirely). I then saved it as an .avs file. I then loaded the new "cleaned" file into Virtualdub and loaded Neat. I then built a new noise profile based on the "cleaned" video, ran Neat Video and saved the AVI as a new file. I do it this way because loading NV into avisynth seems like an obnoxious chore. And anyway, you have faster control over Neat in V-dub, where the GUI settings are there. In any event, the video came out pretty decent. I still have to do some tweaking.
Sanlyn, is this an example of what you do? -
And here's another question: There are currently three Virtualdub filters that work great in conjunction with Neat: Temporal Cleaner, Suppressor of the Noise (Sergey), and Denoise (by the fIsh). Is it better to first filter with one of these, save the AVI and reload it into Virtualdub with NeatVideo, or can one of them be used with Neat in a filter chain? I figure if I go with the first option, it would avoid ghosting
Isn't the Neat Video temporal filter a pretty dumb frame blend?
i.e. no motion compensation, no intelligence, and only basic conditionality? Basically equivalent to AVIsynth's temporalsoften()?
MVDegrainMulti for general noise - as used in the film restoration script - is usually far better.
btw, RemoveDirtMC (also as used in the film restoration script!) is near-magic for single frame junk.
Cheers,
David. -
I find that if used in VirtualDub with other denoisers, NV isn't as effective. Their user guide barely touches on this, but IMO all VDub denoisers are unpredictable when chained with other VDub filters. NV's manual cautions that NeatVideo should be used alone as far as chaining in VDub goes. Maybe it has to do with the way VDub feeds frames to filters for processing (? Ye olde source code sorcerers might have the answer to that). One example is when I load the built-in temporal smoother with VDub in the same chain. It clears up a lot of horrible noise, but -- really -- so much fine detail has been smoothed that the image looks foggy.
Annoying flicker from 8 mm film
By mexuser in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2011, 19:31 -
Flicker on DVD Menu
By Funky Monk in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2009, 17:42 -
Denoising Audio on xvid4psp
By tofuguy in forum AudioReplies: 1Last Post: 1st Dec 2008, 11:01 -
Where to find Benchmark Images to test Deinterlacing, Denoising, Scaling...
By gfxcat in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2008, 20:37 -
Flicker effect
By wan2no in forum EditingReplies: 1Last Post: 26th Jul 2007, 20:38
