How's this?
				Results 271 to 280 of 280
	Awful lot of DCT ringing artifacts. And still a lot of projector bounce. The flicker is gone though. Last edited by jagabo; 15th Jan 2012 at 13:25.
	Ok, at least the flicker is gone which was my biggest challenge.
 Projector bounce is taken care of with stab, I believe(?)
 what about the ringing artifacts?
	Gettin' there, I hope. Here are two 2X pointresize blowups from a portion of a couple of frames in the mpg and script posted earlier in #270 (13 Jan 2012). Not totally satisfied with some of mild bleed. I tried making lines sharper and darker but it started looking a bit overdone and etched. Still working on color. But a tad more antialias might be in order, I think (?).
 [Attachment 10582 - Click to enlarge]
 But I still don't know what to do about the pale ghost in this scene. Spent half the day in doom9 looking up "ghost" stuff, didn't get anywhere.
 [Attachment 10583 - Click to enlarge]
 Same script as before, attached below.Last edited by sanlyn; 21st Mar 2014 at 09:04.
	I think I have found a very good denoising alternative that gives results close to McTemporalDenoise. I am using a combination of Avisynth and NeatVideo in Virtualdub:
 For very dirty clips, I have been stacking Avisynth's TemporalCleaner and TTempsmooth. The luma/Chroma threshold is evenly balanced...that is, I use around 4-5 for Cleaner (modest settings) and a little more for Ttempsmooth, since it tackles background noise rather nicely. The reason for stacking these two is quite simple: Cleaner stabilizes random pixels (dirt), while Smoother takes care of the backround noise and smooths out any remaining dirt.
 I save that script, and then open it in Virtualdub. I load NeatVideo and create a noise profile based on the remaining dirt in my new clip. I then run that through, with around a 40-50% sharpening. Now I know this sounds like alot of smoothing, which would lead to artifacts. However, what most people don't realize is that, if perfectly balanced, Cleaner stabilizes, Smoother cleans and NeatVideo's temporal smoother, being adaptive and not creating ghosting, artifacts, etc. is the perfect finishing touch to eliminating leftover junk...without eliminating a single detail. It's perfect.
 I have to say, the results are SUPERB. Tonight, I plan on posting before/after sample. There might be some slight ringing on the edges (which only show on the computer monitor, but not on my TV after I encode and author). But I could still use some advice to eliminate that, if possible. Otherwise, beautiful video.
	Keep at it, unclescoob. Last edited by sanlyn; 21st Mar 2014 at 09:04.
	Post your sample unclescoob thanks
 As a side note:
 There is a field you haven't exploited yet i believe: working on Y and UV separately , you can do that with Merge http://avisynth.org/mediawiki/Merge
 example:
 avisource("....")
 chromavid = awarpsharp2(depth=28, chroma=4) #
 mergechroma(chromavid,1.0)Last edited by themaster1; 29th Jan 2012 at 11:02. *** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	That was discussed earlier:
 https://forum.videohelp.com/threads/341188-Still-have-flicker-after-Denoising-with-AviS...=1#post2132521
 And several later posts.Last edited by jagabo; 29th Jan 2012 at 11:38.
  Annoying flicker from 8 mm filmBy mexuser in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2011, 20:31
  Flicker on DVD MenuBy Funky Monk in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2009, 18:42
  Denoising Audio on xvid4pspBy tofuguy in forum AudioReplies: 1Last Post: 1st Dec 2008, 12:01
  Where to find Benchmark Images to test Deinterlacing, Denoising, Scaling...By gfxcat in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2008, 21:37
  Flicker effectBy wan2no in forum EditingReplies: 1Last Post: 26th Jul 2007, 21:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
