I set a BD25 reencode last night and I wake up and its stopped at 50% with a "x264.exe has stopped working" window up. I'm doing highest quality, two passes.
It screws up on the second pass.
[13:30:53] BD Rebuilder v0.39.02 (beta)
- Source: XXXX
- Input BD size: 40.09 GB
- Approximate total content: [02:18:54.325]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Quality: Highest (Very Slow), Two Pass
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640
[13:30:53] PHASE ONE, Encoding
- [13:30:53] Processing: VID_00001 (1 of 1)
- [13:30:53] Extracting A/V streams [VID_00001]
- [13:42:48] Reencoding video [VID_00001]
- Source Video: MPEG-4 (AVC), 1920x1080
- Rate/Length: 23.976fps, 199,824 frames
- Bitrate: 16,191 Kbs
- [13:42:48] Reencoding: VID_00001, Pass 1 of 2
- [16:23:49] Reencoding: VID_00001, Pass 2 of 2
^Right as that starts it says x264.exe has stopped working.
- [16:48:23] Reencoding: VID_00001, Pass 2 of 2
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.39.02 (beta)
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: 1.9.42.1, Ok
- FFDSHOW: 3326, Ok
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[16:51:37] - Failed video encode, aborted
Yeah for some reason the second pass starts and it instantly gets the error. Everything is ok in the inspection too. Any ideas?
Reload your rip but BEFORE (this is critical) you start rebuilding anything, check the video files that you have loaded from the rip. Do you see VC-1 with a frame rate of 29.97 in ANY of the video streams? BDRebuilder has a known "bug" where it cannot encoded interlaced VC-1. If you try to ask about this on the official forum on Doom9 you will find the author's friends will insist that you have not set up something correctly and that is the cause of it. Actually the author has admitted that there is a problem with trying to encode interlaced VC-1 video and basically BDRebuilder can't handle it. It's been like this forever so I wouldn't hold my breath on it being fixed. The only "solution" I've found for such discs is to burn them exactly as ripped to BD-R DL media. If you do not have VC-1 in any of the videos you ripped than post what the source BluRay is as maybe someone will know if there's something weird with it.
Yes I did ask here
http://forum.doom9.org/showthread.php?p=1541517&posted=1#post1541517 -
They don't want to help me anymore because its a download. They do realize probably 95% of the people using BD Rebuilder are mostly using downloads.
Pull! Bang! Darn!
A few other sites I go to pretty much ALL use downloads. I personally know a couple dozen people that do as well.
Anyway I may have fixed it. Reinstalled ffdshow and the newest BD Rebuilder. -
tsMuxeR.exe has stopped working
By stblob in forum Authoring (Blu-ray)Replies: 8Last Post: 7th May 2011, 13:24 -
Wavi.exe stopped working
By jcknecht in forum Blu-ray RippingReplies: 11Last Post: 1st Jan 2011, 15:24 -
AVCHD - x264.exe has stopped working
By KlintIstwood in forum Blu-ray RippingReplies: 3Last Post: 27th Jun 2010, 08:17 -
By newpath in forum Video ConversionReplies: 6Last Post: 17th Jul 2009, 16:42 -
%APPNAME%.EXE has stopped working
By beardedboss in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th May 2008, 03:23
