-Hey!-
Congratulations. I've graduated to advanced conversion! Now for my problem:
I had these two huge MOV files. I want to make an NTSC VCD. The files couldn't be converted to AVI directly with QuickTime Pro because of an input/output error. (Don't ask me what that was all about.) So, I used QuickTime Pro to cut the video (which happened to be a concert) into smaller ones by song. I made each smaller MOV independent of the larger one. The framerate on the original and the smaller MOV files was 60fps.
I then converted the smaller MOV files (the ones without the errors, anyhow) into AVI files. I set everything to 'best' on the output, except for framerate, which I set at 29.97. Then, I converted the AVIs into MPGs using TMPGEnc. I created the image using TSCV, set it to NTSC and all that. I burned using CDRWin at 4X (which is the lowest speed it gives me).
My problem was that my final product was a VCD that had macro squares, or whatever the technical term is. I then read a zillion posts and decided to try filters. I've used a zillion templates, as well. What I then came up with was a VCD that had little or no macro squares, only now it freezes in places and then I can't do anything.
This is the oddest problem. I'm using the same medium I've always used. I'm doing everything the way I've always done it. But this is the first time I've converted from MOV to MPG.
I've tried using other ways to convert from MOV to AVI other than QuictTime Pro. But I found that the other programs, such as MOV2AVI give me terrible resolution.
I don't really know what to do. If anyone can suggest something, point me to a template that has worked for them (with AVIs created from MOVs), or tell me that I'm stupid, that would make me feel better.
-Later!-
Eric
you might try opening the mov in premiere and frameserving to tmpgenc... cause everytime you reencode a video you lose quality.
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22 -
Dvd rip(HD) in mac - Mov,mpg,avi
By nimrodm in forum MacReplies: 3Last Post: 9th Feb 2010, 08:33 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
how can i convert .mov to .mpg?
By johnnylonghair1 in forum MacReplies: 4Last Post: 6th Apr 2008, 12:30 -
Playback video too bright in mov, mpg, avi, wmv, etc in all players
By PhilippZ in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 16:02
