Hello there, mates.
I recently bought a Philips BDP3200 Blu Ray Player so I could enjoy some HD Media through my usb flashdrive.
I was aware this player had a limitation when it came to some MKV. It reads only profile 4.1 or less.
Turning profile 5.1 to 4.1, I managed to use tsMuxer + mkvmerge sucessfully (rapidly, I mean).
However, every 10-bit MKV I tried to play didn't work.
Most of them are like this:
"Format : AVC
Format profile : High 10@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames"
This topic comes with the question: Is it possible to convert the file to a playable format without having to reencode and spending a huge time doing it? (I mean, tsMuxer + mkvmerge are very quick, but tsMuxer recognizes High 10 as High profile).
XMedia takes as long as the video's duration to do this, and there's the probability to lose quality if you're not too good in setting up.
A more complete description of one of the files:
Code:General Format : Matroska Format version : Version 2 File size : 375 MiB Duration : 1h 9mn Overall bit rate : 757 Kbps Encoded date : UTC 2011-08-29 12:18:34 Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High 10@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 6 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 9mn Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Scan type : Progressive Writing library : x264 core 116 r2074 2641b9e Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x3:0x133 / me=hex / subme=10 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=8 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.80 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=2:0.60 Language : English Default : Yes Forced : No Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : HE-AAC / LC Codec ID : A_AAC Duration : 1h 9mn Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz / 24.0 KHz Compression mode : Lossy Default : Yes Forced : No Menu 00:00:00.097 : en:00:00:00.097
http://www.hongfire.com/forum/showthread.php/403793-Any-good-Hi10P-(10bit)-to-8bit-video-converters
1ST POST says that this nightly build of handbrake works fine. Try it out.
Convert 10-Bit MKV to 8-Bit
By wingfat in forum Video ConversionReplies: 8Last Post: 2nd May 2013, 20:44 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
Converting 32-bit audio to 24-bit
By Colmino in forum AudioReplies: 10Last Post: 29th Oct 2007, 18:22
