There appears to be a serious bug with ALL recent 5.0 releases of XviD4PSP when running on 64 bit Windows 7.
When converting a .mp4 or .avi encoded with AAC audio to AC3 the audio track is blank (silent). The output audio encoding doesn't make any difference.
Using exactly the same version in Windows XP 32 bit works fine.
I have tried the following versions: 5.10.234.0 (16.4.2011), 5.10.268.0 (26.10.2011), and 5.10.271.0 (07.11.2011).
It appears to be some sort of issue with avisynth and the bassAudio plugin.
Demux works fine - I can hear the audio
Save to WAV creates a file BUT I get no audio when I play the created file.
Looking at the logs, the SCRIPT section shows that with 64 bit Windows 7, the loadplugin(.....bassAudio.dll) line is missing, presumably because the import(...AudioFunctions.avs) line failed. Also there is no AudioDub line, probably because they is no audio track.
So, in conclusion, I believe that version 5.10 is unusable in 64 bit windows 7 if the source file has AAC audio (which is nearly ALL HD video these days).
Logs files attached below.
Kind regards, Graham R.
Here we have the log file from Windows 7 64 bit (which created a file with no audio)...
PLATFORM
OS Code: Microsoft Windows NT 6.1.7601 Service Pack 1
OS Name: Windows 7 Ultimate Service Pack 1 (x64)
Framework: 2.0.50727.5448 (v4.0)
AviSynth: AviSynth 2.58 tsp MT version 5(mod seraphy), build:Jul 12 2009 [07:46:21]
CPU Info: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (~3310), 4 core(s)
RAM Total: 16364Mb
Language: ENA (1252, ".")
SystemDrive: C:
XviD4PSP
Version: 5.10.234.0
Created: 14.04.2011 01:42:08
AppPath: C:\Program Files (x86)\XviD4PSP 5
TempPath: E:\Temp
FILES
Sample.mp4 >
Sample.avi
TASK
Format: AVI Hardware HD
Duration: 00:00:57:224 (1372)
VideoDecoder: DirectShowSource
Resolution: 1920x864 > 1920x968
Aspect: 1.9753 > 1.9835
VCodecPreset: XviD 2P 3000k Extreme
VEncodingMode: TwoPass
VideoCodec: h264 > XviD (1.2.2)
VideoBitrate: 3172 > 3000
Quality: 0.080 > 0.067
Framerate: 23.976
SourceType: PROGRESSIVE
FieldOrder: UNKNOWN
AEncodingPreset: AC3 384k
AudioCodec: AAC > AC3
AudioBitrate: 404 > 384
Samplerate: 48000
Channels: 6
SCRIPT
import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\AudioFunctions.avs")
import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\VideoFunctions.avs")
DirectShowSource("E:\Movies\Sample\Sample.mp4", fps=23.976, convertfps=true)
ConvertToYV12()
###[FILTERING]###
###[FILTERING]###
Lanczos4Resize(1920, 968)
AUDIO ENCODING
Encoding audio to: E:\Temp\0005.ac3
AC3 384kbps 6ch 16bit 48000khz
aften.exe: -b 384 - "E:\Temp\0005.ac3"
VIDEO ENCODING
Encoding video to: E:\Temp\0005.avi
XviD 3000kbps 1920x968 23.976fps (1372 frames)
...first pass...
xvid_encraw.exe: -pass1 "E:\Temp\0005_1.log" -vhqmode 4 -bvhq -lumimasking -max_bframes 1 -nopacked -threads 6 -i "E:\Temp\0005.avs" -o NUL
Tot: enctime(ms) =80918.00, length(bytes) = 106329831
Avg: enctime(ms) = 58.94, fps = 16.97, length(bytes) = 77443
I frames: 21 frames, size = 178900/ 3756912, quants = 2 / 2.00 / 2
P frames: 723 frames, size = 114151/ 82531307, quants = 2 / 2.00 / 2
B frames: 628 frames, size = 31913/ 20041612, quants = 4 / 4.00 / 4
...last pass...
xvid_encraw.exe: -pass2 "E:\Temp\0005_1.log" -bitrate 3000 -vhqmode 4 -bvhq -lumimasking -max_bframes 1 -nopacked -imin 1 -bmin 1 -pmin 1 -threads 6 -i "E:\Temp\0005.avs" -avi "E:\Temp\0005.avi"
Tot: enctime(ms) =117002.00, length(bytes) = 21877603
Avg: enctime(ms) = 85.22, fps = 11.73, length(bytes) = 15934
I frames: 21 frames, size = 68704/ 1442787, quants = 3 / 6.10 / 9
P frames: 723 frames, size = 21094/ 15251029, quants = 3 / 10.28 / 13
B frames: 628 frames, size = 8254/ 5183787, quants = 9 / 16.76 / 20
MUXING
Video file: E:\Temp\0005.avi
Audio file: E:\Temp\0005.ac3
Muxing to: E:\Movies\Sample\Sample.avi
Please wait...
TIME
Total encoding time: 3 min 21 sec
Out file size is: 23.56 mb
The exact same mp4 vidio file converted on Windows XP 32 bit ....
PLATFORM
OS Code: Microsoft Windows NT 5.1.2600 Service Pack 3
OS Name: Microsoft Windows XP Service Pack 3 (x32)
Framework: 2.0.50727.3623 (v4.0)
CPU Info: AMD Phenom(tm) II X6 1090T Processor (~3200), 6 core(s)
RAM Total: 3070Mb
SystemDrive: C:
XviD4PSP
Version: 5.10.234.0
Created: 14.04.2011 02:42:08
AppPath: C:\Program Files\XviD4PSP 5
TempPath: d:\TempXVID
FILES
Sample.mp4 >
Sample.avi
TASK
Framerate: 23.976
FieldOrder: UNKNOWN
AudioDecoder: bassAudioSource
Samplerate: 48000
Channels: 6
Normalize: 100%
Accurate: 10%
Gain: 0.579
SCRIPT
import("C:\Program Files\XviD4PSP 5\dlls\AviSynth\functions\AudioFunctions.avs")
import("C:\Program Files\XviD4PSP 5\dlls\AviSynth\functions\VideoFunctions.avs")
loadplugin("C:\Program Files\XviD4PSP 5\dlls\AviSynth\plugins\bass\bassAudio.dll")
video = DirectShowSource("D:\XvidWork\Sample.mp4", audio=false, fps=23.976, convertfps=true)
audio = bassAudioSource("d:\TempXVID\0686_0.aac")
AudioDub(video, audio)
ConvertToYV12()
###[FILTERING]###
###[FILTERING]###
AmplifydB(0.579)
AUDIO ENCODING
Encoding audio to: d:\TempXVID\0686.ac3
aften.exe: -b 384 - "d:\TempXVID\0686.ac3"
VIDEO ENCODING
Encoding video to: d:\TempXVID\0686.avi
...first pass...
xvid_encraw.exe: -pass1 "d:\TempXVID\0686_1.log" -vhqmode 4 -bvhq -lumimasking -max_bframes 1 -nopacked -threads 8 -i "d:\TempXVID\0686.avs" -o NUL
Tot: enctime(ms) =31594.00, length(bytes) = 736308
Avg: enctime(ms) = 23.01, fps = 43.46, length(bytes) = 536
I frames: 5 frames, size = 20180/ 100900, quants = 2 / 2.00 / 2
P frames: 681 frames, size = 924/ 629244, quants = 2 / 2.00 / 2
B frames: 681 frames, size = 9/ 6129, quants = 4 / 4.00 / 4
N frames: 5 frames, size = 7/ 35
...last pass...
xvid_encraw.exe: -pass2 "d:\TempXVID\0686_1.log" -bitrate 3000 -vhqmode 4 -bvhq -lumimasking -max_bframes 1 -nopacked -imin 1 -bmin 1 -pmin 1 -threads 8 -i "d:\TempXVID\0686.avs" -avi "d:\TempXVID\0686.avi"
Tot: enctime(ms) =28328.00, length(bytes) = 736308
Avg: enctime(ms) = 20.63, fps = 48.47, length(bytes) = 536
I frames: 5 frames, size = 20180/ 100900, quants = 1 / 1.40 / 2
P frames: 681 frames, size = 924/ 629244, quants = 1 / 1.00 / 1
B frames: 681 frames, size = 9/ 6129, quants = 2 / 2.00 / 3
MUXING
Video file: d:\TempXVID\0686.avi
Audio file: d:\TempXVID\0686.ac3
Muxing to: D:\XvidWork\Sample.avi
Please wait...
TIME
Total encoding time: 1 min 9 sec
Out file size is: 3.40 mb
Not if you are running 64 bit Windows and do lots of video conversions.
Xvid4PSP is too slow with Windows 7 x64-bit
By bugsboney in forum Video ConversionReplies: 16Last Post: 13th Feb 2015, 17:05 -
Xvid4psp does not work on Windows 7 64 Bit version
By pectin232 in forum Video ConversionReplies: 0Last Post: 28th Nov 2010, 18:41 -
XVID4PSP 6.0 2-pass, and Windows 7 64-bit question.
By x2x3x2 in forum Video ConversionReplies: 0Last Post: 25th Jul 2010, 09:46 -
how to encode aac 5.1 to ac3 on the fly in 64-bit windows 7
By MR 3 in forum AudioReplies: 3Last Post: 4th Apr 2010, 17:47 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 01:41
