Hi
When I do standard def transcodes for my CRT - I use color range of 16-235
If I want to do standard def transcodes for a high-def TV should I use the same color range?
Does it matter whether it is LCD or Plasma?
TIA
16 black and 235 (nominal white) is standard for most video
DV/DVD/ASTC/DVB/H.264/HDV/AVCHD/Blu-Ray/etc.
The levels 236-255 are reserved for transient overshoots. Consumer camcorders often use these levels so will appear over white unless adjusted down to 235.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Note that high def digital video usually uses rec.709 rather than rec.601 color. The luma channels have the same range (16-235) but the colors are handled differently.
https://forum.videohelp.com/threads/329866-incorrect-collor-display-in-video-playback?p...=1#post2045830Last edited by jagabo; 26th Nov 2011 at 20:29.
Thanks edDV and jagabo
I do own an HD 24" Monitor but not an HD TV as yet
Do most/any HD TV's have a "color range" setting - in which case a video with PC.601 range can be displayed as rec.601 or vice-versa? -
An HDTV set will usually assume an SD source is BT.601 and an HD source is BT.709. This is mainly an issue for encoding media not watching. The differences are small so will only be noticed by HD geeks.
http://en.wikipedia.org/wiki/Rec._709
http://en.wikipedia.org/wiki/Rec._601Recommends: Kiva.org - Loans that change lives.
High def onto a DVD?
By enchant3 in forum Authoring (DVD)Replies: 5Last Post: 17th Feb 2011, 07:17 -
What do I need to make high def movies?
By so in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2009, 18:30 -
high def played on pc
By thecrock in forum Newbie / General discussionsReplies: 5Last Post: 9th Jul 2008, 18:20 -
How may I record in High Def and Playback in High Def ?
By MacPCConsultants in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jun 2008, 17:28 -
high def and DVD-VR
By feh in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2008, 14:03
