whenever i try to encode something with tmpg in winxp , after i burn the cd using nero , and play it on my dvd player the sound is always messed up . This only happens in win xp pro , before in win 2k i did not have this problem. Also i know its not my dvd player because whenever i burn vcd or svcd iso's they play fine in my dvd player(samsung m301). I know im using the correct setting when encoding because i use the built in wizard. Also when i try to burn the mpeg to the cd , its says its no vcd 2.0 comliant even know its supposed to be , because when using the other operating systems , its worked great. So what can be the problem? Please help, and thanks in advance.
Results 1 to 1 of 1
cloning winXP system disk problem
By deejay.2001 in forum ComputerReplies: 1Last Post: 15th Jun 2009, 15:54 -
Win95, Win98 and WinXP
By Jomapil in forum ComputerReplies: 9Last Post: 4th May 2009, 13:41 -
Does WinXP fix a known Win2k problem?
By bevills1 in forum ComputerReplies: 6Last Post: 28th Feb 2009, 23:34 -
Auto play problem in WinXP SP2
By bevills1 in forum ComputerReplies: 4Last Post: 3rd Mar 2008, 11:09 -
problems with v2.5 install on winxp
By welthqa in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Aug 2007, 16:37
