hi guys , i recently added subtitles to a movie last night and when i added the subtitles into the new movie it went from 1.45gb (original size of avi) to 2.35gb , is that normal? is there no way to keep the same size of original avi.
thanks!
It seems you reencoded the movie with burnt in subs.
The size of the new file depends on the settings you choose for saving video and audio.
However, do you really need to make hard subs?
Can't you just display them as text from a separate file? -
Adjust the bitrate to reduce the file size. Use same as your source for same size. Under video->compression->your codec->settings.
Hey alan yeah i need to add them into movie as its for that film the thing where theres alooot of norwegian speaking parts and i want it on a disc.
Baldrick to the rescue once again hehe thanks mate i didnt know you could change bitrate and stuff =)
Weird Problem - Adding subs to avi doesn't work okey on DVD Player
By andreas.cro in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2012, 13:29 -
Adding subs to avi format?
By Avon in forum SubtitleReplies: 2Last Post: 14th Aug 2011, 13:20 -
how to get correct aspect ratio when adding subs to avi file using auto GK
By neds81 in forum SubtitleReplies: 5Last Post: 29th Dec 2009, 19:01 -
Adding subs to a .avi file
By stgdlf in forum Newbie / General discussionsReplies: 7Last Post: 21st Nov 2009, 01:34 -
Adding Subs to Avi
By ill_kuma in forum SubtitleReplies: 7Last Post: 9th Feb 2009, 21:02
