I get the following error message when I open Adobe Audition 3:
I shut down Audition and reopened to the same error message. I uninstalled Audition and reinstalled, but still got the same error message. I am using Windows 7 64-bit. I've never had this problem before. Any suggestions?Shutting down... To continue working where you left off, please restart Audition.
Thank you.
Probable user configuration corrupter
Try rename Audition user folder in location: C:\Users\<username>\AppData\Roaming\Adobe\Audition
rename folder from Audition to for example Aud
So when Audition run, its not found Audition user folder, so its create and load default configuration. -
Why not use some real musician's software like Ableton Live, among others.
Adobe Audition 3.0 imports as 32-bit
By ranosb in forum AudioReplies: 4Last Post: 29th Jun 2011, 00:35 -
Adobe Audition
By nic3 in forum AudioReplies: 1Last Post: 27th Jan 2011, 12:36 -
How would I slow audio down 4% using Adobe Audition?
By Hittz in forum AudioReplies: 11Last Post: 2nd Jan 2011, 03:53 -
Adobe Audition Mixdown Problem
By EmpireStrikesBack198 in forum AudioReplies: 3Last Post: 31st Mar 2010, 15:24 -
Adobe Audition Mixdown- Slow audio
By tharps22 in forum AudioReplies: 0Last Post: 30th Nov 2009, 00:04
