Hi All!
I'm new here to the forum and pretty glad I found it!
I have a question for the expertsI'm trying to find a machine that will allow me to record from dvd to vhs and vhs to dvd, I also need it to be able to record in PAL and NTSC...is there such a machine? I would need to be able to send tapes to the US.
I looked at a Panasonic DMR EZ49 but I'm pretty sure that's just PAL?
I hope somebody can offer some advice, I'm pulling my hair out
Many thanks!
Videohell
You do not say where you are from but.....
Most vhs/dvd recorder combos only record in one system beit PAL or NTSC. Some tme ago, there were some machines sold by Philips that could record NTSC tapes on to PAL disks using the PAL60 system.
No combo will do multi-standard as you hope. If they did, half the topics in these forums would be redundant. -
Sorry, I'm UK based. Sounds like I could be out of luck then?
Thanks for the link and info!
720p video on a 1080p TV, and vice versa?
By sldvd in forum Newbie / General discussionsReplies: 15Last Post: 16th Jun 2011, 21:21 -
How to convert 5.1 to 2.0 AC3 and vice versa
By lapetite_66 in forum AudioReplies: 5Last Post: 8th Mar 2010, 19:30 -
What is best way to convert vob files from pal to ntsc and vice versa?
By hibbs in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2010, 19:41 -
How to convert fullscreen to widescreen and vice versa?
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 16th Jul 2009, 23:01 -
change avi from 16:9 to 4:3 and vice versa
By slowjoe in forum EditingReplies: 9Last Post: 6th Jun 2007, 07:11
