Results 1 to 12 of 12
    Nov 2011
    Ukraine
    hello guys
    there is a problem with image
    I have a player sony svo-5800 (ntsc--ntsc tipe--oun monitor ntsc===back & white )
    and still black and white picture
    connected the player to capture the map
    as well as connect to the TV tried to
    and everywhere was black and white picture
    I did a lot of the menu settings and nothing does not help
    if someone has faced such a problem, tell me what to do
    may have nuances settings ??
    ps
    sorry for my english
    Nov 2011
    Ukraine
    perhaps
    that the image is black and white
    of a player's ntsc j and record on tape ntsc (american)
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You need an NTSC compatible TV or monitor. An NTSC SVO-5800 will not export to PAL or PAL60 or SECAM.
    http://www.kiva.org/about
    Nov 2011
    Ukraine
    I know it
    problem arises when using color svo 5800 ntsc+tipe ntsc+monitor ntsc==black&white
    why, I can not understand
    I tested connecting to a TV and a monitor, they support the standard ntsc
  5. Member edDV's Avatar
    Mar 2004
    I know it
    Does this happen on all tapes even a commercial VHS NTSC tape?
    It could be the problem tapes were recorded from a PAL60 source. This would play monochrome since subcarrier is at 4.43 MHz and PAL, not normal NTSC 3.58 MHz.
    Nov 2011
    Ukraine
    all of the tapes were brought from the USA
    promo tape
    they NTSC
    player also brought from the USA
    so I'm sure that all of the same standard
    ps
    under the scheme connected my second player sony vo5850
    and all the great shows
    I first encountered this problem
    I can not understand where the error
  7. Member edDV's Avatar
    Mar 2004
    My best guess is the monitor isn't NTSC compatible.
    Try to capture NTSC to a computer. See if that is color.
    Nov 2011
    Ukraine
    I did so
    connected to your capture card
    and get a black and white image -((
    I thought that the problem with the settings
    but I have tried everything
    ps
    two of my other players LD & Umatic show excellent
  9. Member edDV's Avatar
    Mar 2004
    ps
    If playing the same tapes, that indicates a failure in that VCR.
    Nov 2011
    Ukraine
    ps
    no
    failure to have no
    they show well, the picture color
  11. Member edDV's Avatar
    Mar 2004
    ps
    no
    failure to have no
    I thought you said the tapes play in color on other VCR players.
    Nov 2011
    Ukraine
    probably not expressed
    I want to say that the rest of the equipment is connected in the same way and works fine
    does not want to work then vcr 5800
    I can not understand what it is connected
    Need some details of the settings ..
    may need an additional supply that is ?
