I'm looking to fix the horizontal jitter in my video which was caused by crappy VHS equipment. It looks like bad interlacing artefacts. You can't really see it when you play the video on your PC so I've also provided a DVD ISO if you'd like to check it on your TV.
Here's an 8 second sample MPEG 2 video.
Here's the DVD ISO.
I looked at the DeJitter plugin but I can't figure out how to use the correct settings to fix my video. Could someone please suggest a script that I could use. I'm not bothered what plugin it's for as long as it works. Thanks
I've modified the Stab() filter for this, but too much jitter can still overpower it.
Not sure if you ever found an answer to this.Want my help? Ask here! (not via PM!)
How to Fix Patchy Colour with Avisynth?
By VideoFanatic in forum RestorationReplies: 59Last Post: 14th Feb 2012, 10:20 -
Is it possible to Fix Bad Reception Artefacts with AviSynth??
By VideoFanatic in forum RestorationReplies: 6Last Post: 15th Nov 2011, 15:31 -
video with alot of horizontal jitter
By spiritgumm in forum Video ConversionReplies: 14Last Post: 24th Aug 2010, 13:35 -
best avisynth filter for vhs horizontal screen bend?
By spiritgumm in forum Video ConversionReplies: 3Last Post: 9th Aug 2010, 12:22 -
What if TBC doesn't fix the vertical jitter?
By moxiecat in forum RestorationReplies: 8Last Post: 1st May 2009, 06:31
