  1. I am trying to cut ACDHD MTS files without re-encoding.
    TSSniper used to work fine. I stopped doing it for a few months. The main installation of software was Adobe CS 5 during this time. Then TSSniper started to complain there is problem with splitter
    DirectShow problem - Failure while trying to connect file source output pin to preferred splitter/demuxer filter input pin
    I went into setting to manually set splitter. Only MainConcept MPEG Demultiplexer worked but it complained as well
    The splitter does no provide the capabilities required to select audio streams.
    The result is that there is no audio when playing back in TSSniper.
    What can I do to fix the splitter problem?
    Is there an alternative to TSSniper?
    Thanks!
    Have you tried (re)install haali media splitter?
  3. Yes. If I choose it, I got
    DirectShow problem - Failure while trying to get input pin to preferred splitter/demuxer filter
  4. Just to report:
    Setting Haali Media Splitter (AR) as the splitter seems to work.
