Hi all,
I have a feeling this isn't the ideal place to post this but I'm not sure where else to.
Based on your own experiences, how do you go about determining which release it is you really want? For instance, let's say I go to Amazon and find 4 different versions of a film on DVD. You click on each link and notice that the reviews are all the same and the specs are all identical. What now? One version is Widescreen/2.0 Mono, another Fullscreen/2.0 Mono, another Color/Widescreen/1.0 Mono and the last B&W/Widescreen/5.1 Surround. Where do you go to compare, find, hone in on and buy the exact version you want? I always say I'm not the best at wording things but I'm sure you've encountered similar situations to what I provided.
Is there a site that compares versions and specs? What are the best methods of finding out what I'm referring to when all else fails?
Thanks,
Justin
try going to google and type "dvd version compare" or some other variation.
http://www.dvd-basen.dk/uk/home.php3
it doesn't directly compare DVD versions, although the DVDBeaver site does:
http://www.dvdbeaver.com/film/reviews.htm
But if there are reviews of the different versions out there, you can usually find them at DVD Basen. -
it sounds to me like i want to sell you at-least one out many!...let's say I go to Amazon and find 4 different versions of a film on DVD. You click on each link and notice that the reviews are all the same and the specs are all identical. What now? One version is Widescreen/2.0 Mono, another Fullscreen/2.0 Mono, another Color/Widescreen/1.0 Mono and the last B&W/Widescreen/5.1 Surround. Where do you go to compare, find, hone in on and buy the exact version you want?
just buy one which suite your taste! and come-back again all confused!
LOL!
ummm, i just did it and the 1st thing it returned was this site: http://www.dvdcompare.net/
maybe you spelled DVD wrong.
pctv TVCenter versions & multiple installs
By Davalan in forum DVB / IPTVReplies: 0Last Post: 15th Apr 2011, 04:35 -
dvd/bluray release versions site?
By mostin5000 in forum Newbie / General discussionsReplies: 10Last Post: 23rd Sep 2010, 04:54 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 15:50 -
DVD w/ two versions (theatrical and unrated)... problem
By extrabyte in forum DVD RippingReplies: 4Last Post: 5th Jan 2009, 21:41 -
help in selecting chapt of different versions on DVD to rip
By willcarson in forum MacReplies: 2Last Post: 16th Jan 2008, 09:05
