  1. i have MP4 video that i want to import into vegas. i used to GSpot, it has mp4v video codec, mp4a audio codec
    when i try to import to vegas it says "may be corrupted" or "cannot be opened"
    its definitly not corrupted since i can play it in VLC and WMP
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    It should load - I've just tried a few mp4 files and everything is OK. Why don't you post a MediaInfo report on the file. Also what version of Vegas are you running?
  3. Vegas 9.0e build 1147
    Format                           : MPEG-4
    Format profile                   : Base Media
    Codec ID                         : isom
    File size                        : 99.1 MiB
    Duration                         : 11mn 36s
    Overall bit rate mode            : Variable
    Overall bit rate                 : 1 194 Kbps
    Writing application              : Lavf52.32.0
    Video
    Format                           : MPEG-4 Visual
    Format settings, BVOP            : Yes
    Format settings, QPel            : No
    Format settings, GMC             : No warppoints
    Format settings, Matrix          : Default (H.263)
    Codec ID                         : 20
    Duration                         : 11mn 36s
    Bit rate                         : 1 056 Kbps
    Width                            : 512 pixels
    Height                           : 384 pixels
    Display aspect ratio             : 4:3
    Frame rate mode                  : Constant
    Frame rate                       : 29.970 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Compression mode                 : Lossy
    Bits/(Pixel*Frame)               : 0.179
    Stream size                      : 87.7 MiB (88%)
    Writing library                  : DivX 5.1.1 (Maupiti) (UTC 2003-11-19)
    Audio
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 3
    Mode                             : Joint stereo
    Mode extension                   : MS Stereo
    Codec ID                         : 6B
    Duration                         : 11mn 36s
    Bit rate mode                    : Variable
    Bit rate                         : 133 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 48.0 KHz
    Stream size                      : 11.1 MiB (11%)
    Writing library                  : LAME3.90.3
    Last edited by Thunderhead2772; 23rd Nov 2011 at 21:06. Reason: forgot to mention vegas version
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Seems OK maybe it's the codecs in Vegas? By way of example here are the details pf one of my mp4 files that open without difficulty in Vegas 9 and this file has chapters embedded as well.
    Format                           : MPEG-4
    Format profile                   : Base Media / Version 1
    Codec ID                         : mp41
    File size                        : 684 MiB
    Duration                         : 2h 4mn
    Overall bit rate                 : 767 Kbps
    Encoded date                     : UTC 2005-07-15 04:36:02
    Tagged date                      : UTC 2005-07-15 04:36:02
    Video
    Format profile                   : Simple@L0
    Format settings, BVOP            : No
    Codec ID                         : 20
    Duration                         : 2h 4mn
    Bit rate                         : 601 Kbps
    Maximum bit rate                 : 1 850 Kbps
    Width                            : 560 pixels
    Height                           : 240 pixels
    Display aspect ratio             : 2.35:1
    Frame rate                       : 25.000 fps
    Color space                      : YUV
    Bit depth                        : 8 bits
    Stream size                      : 536 MiB (78%)
    Writing library                  : em4v 4.1.6.5
    Language                         : English
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format profile                   : LC
    Codec ID                         : 40
    Duration                         : 2h 4mn
    Bit rate                         : 160 Kbps
    Maximum bit rate                 : 164 Kbps
    Channel positions                : Front: L R
    Stream size                      : 143 MiB (21%)
    Title                            : Nero Digital Audio 2-ch Unspecifi
    Language                         : English
    Menu
    00:00:00.000                     : Chapter 1
    00:10:09.300                     : Chapter 2
    00:16:37.600                     : Chapter 3
    00:23:57.700                     : Chapter 4
    00:32:33.000                     : Chapter 5
    00:39:21.300                     : Chapter 6
    00:45:59.700                     : Chapter 7
    00:52:34.800                     : Chapter 8
    00:59:02.000                     : Chapter 9
    01:05:35.200                     : Chapter 10
    01:14:00.300                     : Chapter 11
    01:20:18.300                     : Chapter 12
    01:28:36.600                     : Chapter 13
    01:34:53.400                     : Chapter 14
    01:41:28.100                     : Chapter 15
    01:48:15.200                     : Chapter 16
    01:54:50.300                     : Chapter 17
  5. vegas is highly sensitive to codecs and encoder settings.
    if you have source with you, just re-encode to DV-AVI before taking it to vegas which indeed give you better quality.
  6. It looks like regular divx or (xvid) /mp3
    If you re-wrapped into AVI container it would probably work. You could use avidemux (in copy mode) or maybe avi-mux gui
  7. @poisondeathray
    it is regular XViD encoded with ffmpeg (with tons of quality settings) in mp4 container (un-necessary) with fourcc tweaked.
    so if he just wanna use fmpeg better option would be dv-avi that vegas won't deny.
  8. the mp4 is actually a remux of an avi file using ffmpeg
    i remuxed it because for some reason certain sections of audio kept getting garbled up or out of sync after awhile when i edited the avi file in vegas. i thought maybe using a different container format might help... i guess not. ill post a new thread about how to fix that
