I've got a Sony RDR-HX780 DVD recorder. Does anyone know what codec it uses when you burn a DVD and finalize it? I had an issue with playing the DVDs in Windows 7 but have since figured it out by installed a codec bundle. Curious though which codec it actually demands its players to have and whether this is unique to Sony DVD Recorders.
dvd can only be mpeg. 99.99% mpeg-2 - 720x480 in ntsc land.
ok - so why do you figure then that Windows 7 wouldn't have an MPEG-2 codec to play it? or are there several MPEG-2 codecs out there of which the one that the Sony recorder uses doesn't shop out-of-the-box with Windows 7?
As far as technology goes....DVD's MPEG2 is "older than dirt" (although FAR from obsolete and FAR from being a product of history). If your finalized discs do not play in a computer running Windows 7....you are doing something wrong....plain and simple. DVD is MPEG2, it can be nothing else.
Strange then ... after installing a Windows Codec pack, it worked. Before that, Windows Media Player didn't recognize it. It played "out of the box" on my XP system. Interested in any other ideas.
Unless I'm mistaken, no stock Win PCs (XP, Vista, or 7) - with the possible exception of MediaCenters - come out-of-the-box with an MPEG2 decoder installed. One must get one (either through getting a DVD-player software app, or by buying Microsoft's WMP MPEG2 plugin, or by getting a freeware/shareware Direcshow codec). Did your "out-of-the-box" come preinstalled with a DVD player software? That's probably why...
BTW, watch out for those "codec bundles"!
Problem making chapters with RDR-HX780 Sony HDD recorder
By 1234567 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2010, 10:56 -
SONY RDR-VX535 help?
By Loader09 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 9th Nov 2009, 19:05 -
Replacing a HDD on the Sony RDR-HX780 or Pioneers WITHOUT a service remote!
By highvolumeJP in forum DVD & Blu-ray RecordersReplies: 5Last Post: 9th Dec 2008, 11:56 -
Is Sony RDR-HX720 compatible with Sony HT-SS2300
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Nov 2008, 09:14 -
Sony RDR-HX750
By woutie in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Sep 2007, 09:54
