Hi all.
i am currently capturing some 8mm tapes for a friend whos camcorder stopped working but the only camcorder i have access to only has composite out, so not wanting to spend a fortune for a capture card on this pc i went with a USB capture dongle.
To be fair it does a pretty good job but the only problem i have is i can not adjust the capture bitrate for the mpeg2, which by default is around 8000 kbps. most of the tapes will be small enough to fit straight onto a single layer dvd but a couple are around 5gig.
which would be the best way to reduce these files, i know best is subjective and i would like to not start learning avisynth.
ATM i reincode with avidemux to a lower bitrate then author to dvd, would it be better to author to dvd then shrink it with dvdrebuilder? or use something else to reduce the bitrate?
alan
Thanks to both of you, i will check both ways and see if i can notice any difference.
Reencoding VC-1 WMV at lower bitrate
By casimps1 in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 23:34 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
How do you lower bitrate but maintain quality?
By zanos in forum Video ConversionReplies: 7Last Post: 11th Dec 2008, 01:43 -
reencode x264 to lower bitrate
By reb0rn in forum Video ConversionReplies: 2Last Post: 12th Jul 2007, 01:54 -
Bitrate always comes out lower?
By MrMors in forum Video ConversionReplies: 6Last Post: 1st Jun 2007, 08:37
