I have some avi file 90 minutes long. On my standalone some will only play to 20 mins but on PC will play all the way. How can this be?
Results 1 to 10 of 10
It could depend on how they are encoded. When I got a new Philips DVD player I found that some of my AVI's that had Mencoder listed in Mediainfo they would not play all the way to the end. Had to use MPEG4modifier to get rid of it. Then they worked fine. Pain in the neck as I had close to 100 of them, but it saved me having to re-do them all.
I don't have any idea. I have a friend that has the same make & model of Philips that I do & it does the same thing in his. What kind of DVD player do you have?
It could be many things. Some players are limited to 1 GB or 2 GB files. It could be the use of features the Blu-ray player doesn't support: GMC, QPEL, too high a bitrate peak. The file may be corrupt. Software players on the PC tend to be much more robust than Blu-ray players and TVs (with built in media players).
Also depends on how you are watching the avi,if it's on a usb hdd or stick then it could be corrupted by copying it,if so just copy it again to the usb device.
It could be one of the issues that jagabo mentions. What standalone are you using? Does it mention any limitations on what it will play in the manual?
Run one of the 'problem' videos through MediaInfo, in Tree View, and copy/paste the information here. Someone might be able to notice what your standalone player may not like about the video.If cameras add ten pounds, why would people want to eat them?
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
mp4 video not playing for the full length in vlc player
By sumeshkri in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2010, 17:50 -
DVD Player problem playing .avi
By dexter30 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Sep 2009, 00:18 -
Disable full screen for TV when playing AVI
By slav in forum Video ConversionReplies: 2Last Post: 18th Dec 2008, 23:07 -
Burning 10 full length vids into a DVD9
By maggot6sic6 in forum Newbie / General discussionsReplies: 18Last Post: 23rd May 2008, 23:06
