i used the super video template in nero 5.5.0.3 and i created a menu with 5 items that are represented by thumbnails of the scenes. After burning it, I play it back through my dvd player and the screen is first of all flickering, as if the tv is using a different refresh rate, and secondly, i notice that the pic is black and white instead of color. Aside from the screen flickering, i can still access the scenes which play flawlessly. If there is a file/patch or anyone who knows of a working version of nero to overcome this problem, I'd appreciate any feedback.
Are you playing this on the APEX 1500; Because the exact same thing happens to be everytime I burn a SVCD; the problem can be solved by pressing the P/N key; (PAL/NTSC); For some reason the palyer gets set to multi and so we need to reset it to NTSC
thanks,
Satish -
I have a Pioneer-440. P/N key? Is that on the dvd player itself? I assume there is no solution on the software side of things .... I was hoping it was the version I have, maybe they released a newer build that solves this problem.
Can I use Nero to join DVD with menu?
By csh in forum EditingReplies: 3Last Post: 12th Nov 2007, 10:58 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 13:48 -
Menu Music with Nero Vision
By Smudge249 in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2007, 05:09 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 12:26 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 11:46
