I have been capturing several old vhs tapes of home videos to DV-AVI using the advc110 and the capturing tool that comes with Windows 7 (I guess it is associated with Windows Live Movie Maker). When I view the file info on any of these files using Windows it says the audio bit rate is 1024kbps and audio sample rate is 32khz (which isn't correct). However, I just downloaded VirtualDub, and it lists the correct 1536kbps and 48khz when I view the AVI audio information from within the program. Since the capture is happening over firewire and the advc110 is set to 48khz, that must be the true value...
So, would it be possible that the Windows capture utility writes the wrong header information on the file? If so, is there a good way to edit this information so that the correct values are stored? I took a segment of a file and did a direct stream copy in VirtualDub, and the resulting file showed the correct 48khz when viewing the file info through Windows. I assume that process is 0% loss in video/audio quality.
My plan is to burn the AVIs to blu ray discs for storing and sharing with family in the future, so I want to reduce the risk of problems. Will I run into problems playing on different devices or get poor audio quality if the header information in the file lists incorrect audio rates? That's my only concern. I'd rather not have to redo all these vhs tapes with different capturing software...I guess I could always do a direct stream copy of all these files in VirtualDub to get files with the correct information, but that'll take a long time, too, and I'm looking for a quicker method if you think I'll run into problems in the future.
Thanks!
What does MediaInfo and VLC(under Tools->Codec information) say?
Yep, the virtualdub process with direct stream copy is lossless. You can use a virtualdub batcher like http://sourceforge.net/projects/virtualdubbatch/ to batch all, you save the project for one file in virtualdub and then load all avis in the batch tool and apply the project for them. -
You are correct to set your ADVC-110 to 48KHz for DVD or Blu-Ray destination.
I haven't used Windows Live Movie Maker yet so can't explain the error.
Instead, I suggest you use WinDV for DV-AVI capture. Instructions here.
http://www.windowsmoviemakers.net/PapaJohn/61/WinDV.aspx
The captured file will be DV video format with uncompressed 16 bit 48KHz PCM Stereo audio in an AVI wrapper. This DV-AVI file can be imported into most editing or DVD authoring programs.
PS: Baldrick's suggestion is an alternate method.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks for the reply. Below is the information that VLC and MediaInfo display. The information appears correct (48kHz) through both of these programs. Do you know if these programs look at the file header information only or do they interpret the values? Since Windows 7 File Information Details shows 32kHz, maybe it is Windows 7 that is either reading the header wrong or doing an incorrect interpretation of the file it captured...
Worst comes to worse, my understanding is that the DV is "wrapped" in an AVI format. If I use direct stream copy on all of these files through VirtualDub, the only thing that would do is update the "wrapping" (apparently correctly whatever header inconsistency exists), and the actual content bits stay exactly the same?
VLC:
Codec - PCM S16 LE (s16l)
Sample rate: 48000 Hz
Bits per sample: 16
Media Info:
Format : AVI
Format_Commercial_IfAny : DV
Format profile : OpenDML
File size : 25.9 GiB
Duration : 2h 8mn
Overall bit rate : 28.9 Mbps
Video
Format : DV
Duration : 2h 8mn
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Chroma subsampling : 4:1:1
Bit depth : 8 bits
Scan type : Interlaced
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Stream size : 25.9 GiB (100%)
Audio
Format : PCM
Muxing mode : DV
Muxing mode, more info : Muxed in Video #1
Duration : 2h 8mn
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 0.00 Byte (0%)Last edited by newtotheworld; 21st Nov 2011 at 22:25.
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 08:20 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 17:07 -
Transcoding Video - Bitrate, Sampling Rate etc Limits?
By Leo48 in forum Newbie / General discussionsReplies: 18Last Post: 22nd May 2008, 08:38 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 10:23
