1) I typically export using MC AVC H264 and the videos come out very dark (using FRAPs to record). They did this before when I used StaxRip as well. Seems to be a FRAPs only thing. How do I remedy this?
2) For Vegas users, whats the significance of the settings in Project > Properties? Does that have any effect on compression settings? I've noticed it's not set correctly but it's also a separate set of options from the compression screen, so I'm having trouble understanding what it's for.
Thanks all!
The project setting defines the timeline. Usually you will set the timeline to match the source. When doing mixed format editing, you usually set project to the primary source.
For example, if you shoot 1080i HDV and set the project to HDV, then the timeline will be HDV. If you import a 720p file to the timeline, it will be converted to 1080i for preview. Final rendering can be to various formats.
The main reason to set the project to match source is to minimize computation when scanning or scrubbing video on the timeline.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Render settings questions for MainConcept/AVC/AAC (*mp4) in Sony Vegas
By vid83 in forum EditingReplies: 10Last Post: 22nd May 2011, 03:55 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Sony Vegas Pro 9.0 & HF 200 - A few beginner questions
By bds in forum EditingReplies: 4Last Post: 2nd Feb 2010, 17:34 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Aspect ratio questions with Sony Vegas & Instructional DVDs
By RockWood610 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jan 2008, 17:22
