Hi Everyone
I`m a newie to the site ,so i say hello to all .
I have a problem with my camcorder as it will record for 2 secs and then stops try again the same thing ,i have tried to reset the unit ,no luck .
Everything else works fine with taking normal pictures ect .
This has only just happened so i am a bit stumped as to why this has happened ,can anyone help please.
It has not been dropped as i am very careful with my equipment .![]()
Many thanks
Gary
I have a similar JVC camcorder with hard drive and I haven't had that problem. Sort of obvious stuff, but are you sure your HDD has enough room? And that it's not set to record to a Micro SD disc, if it has that option? It takes still pictures OK. They are a lot smaller than HD video, so if you take a lot, does it seem to quit with those also?
Sorry, not much else I can think of. Maybe others here have some ideas. If not, maybe a HDD problem.
And welcome to our forums.
hi Redwudz
there`s plenty of space on the hard drive and i cant find an option to record to the SD card ,if it is a hard disk problem are they just a 2 1/2 inch drive that can be changed .
It maybe the case that i have to send it in for repair
Utility for JVC Everio Camcorder
By masfia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th Sep 2010, 05:53 -
Date/time stamp transfer on JVC Everio HD camcorder
By lakin007 in forum Video ConversionReplies: 3Last Post: 11th Jul 2010, 18:37 -
Date/time stamp transfer on a JVC Everio HD camcorder
By lakin007 in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2009, 00:45 -
Remote control JVC Everio GZ-HD10U camcorder.
By 872156 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Jun 2009, 17:51 -
Help with my JVC Everio?
By LITEONDVD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 18th Aug 2007, 23:31
