    Feb 2005
    I have several WMV files that I've been trying to convert for burning to DVD. When I open them just as they were downloaded, it is obvious that the aspect ratio is wrong, and that they should be 16-9 instead of 4-3. This is easily fixed using MainConcept; the resulting file looks fine, but the sound gradually goes out of sync, as is often the case when converting WMV with MainConcept (in my experience).
    If I convert them using AVStoDVD or DVDFlick, the sound stays in sync, but the aspect ratio is still wrong. It might be incorrect to say that the aspect ratio is wrong; the proportions of the resulting file are correct. It is an aspect ratio of 16-9, wide and relatively short rather than almost square. But the content of the picture still looks wrong; the figures appear tall & skinny, like an El Greco painting.
    I had no luck using FitCD to resize, but I don't know if I'm using FitCD correctly or even if resizing is the correct solutioni.
    I've included a screenshot of GSpot.
    Any way to fix this?
Name:	screenshot of gspot.JPG
    Oct 2005
    666th portal
    try using mediainfo on the file in text mode. copy paste the results here. it may give more info.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    DVD requires a 720x480 encode for 4:3 or 16:9. The pixels are non-square.
    If you look at a 16:9 "wide" render in square pixels it should look "tall and skinny". The DVD player (hardware or software) will stretch the frame horizontally to 16:9 for display.
    http://www.kiva.org/about
