I have an MKV file
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Container profile=Unknown@4.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 32mn
Nominal bit rate : 864 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.039
I have tried 2 times to encode this to a pal mpeg2 dvd compliant file in TmpGenc 4 to then author to dvd.. The file encodes ok but on testing both times it comes back as very jittery playback that would make you sick if you watched it! Is there anything i can do with the mpeg 2 files or a setting i have to use with the original MKV to rectify this problem??
Thank you
Did you make the mkv file? If you did I would suggest dropping Format settings, ReFrames : 8 frames to say 4
If it came your way? then maybe try another DVD authoring program like VSO COnvertXtoDVD and see how that handles the file.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
MKV - DTS to AC3 nightmare
By aaron1104 in forum AudioReplies: 29Last Post: 1st Mar 2015, 11:46 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
By aaron1104 in forum Video ConversionReplies: 1Last Post: 11th Oct 2009, 03:17 -
DTS nightmare goes on
By vertical in forum Newbie / General discussionsReplies: 16Last Post: 2nd Nov 2007, 10:40
