    Dec 2005
    Canada
    If I'm understand 25 > 29.97 pulldown, it's essentially creating six frames from five by repeating fields?
    Assuming the existing frames/fields are:
    1T 1B
    2T 2B
    3T 3B
    4T 4B
    5T 5B
    Which fields (Top/Bottom)are being used from which frames to do this.
  2. Yes, it repeats fields in a 3:2:3:2:2 pattern. I don't know exactly where in the sequence it starts. But assuming it's as I listed it:
    1t 1b 1t 2b 2t 3b 3t 3b 4t 4b 5t 5b
    Every now and then it has to make up for the difference between 60 fields per second and 59.94 fields per second. So it drops a field every 500 frames.
    Dec 2005
    Canada
    Thank you, that's the sequence I was trying for.
