    Dec 2003
    belgium
    Hello people, hope everything is ok with you
    Here is the deal:
    Im authoring a dvd using dvd architect, the dvd is 99% done, im only having trouble creating a simple button image,
    my goal is to use an image to next to the title, to let the viewer know where he is pointing at, example:
    PLAY ALL (image)
    CHAPTERS
    CREDITS
    I want also the image to be use in all the buttons
    i read somewhere i should use PNG format in order for transparency to work, which it does
    my problem is, i really don't get how DVDA works with mask and frames etc etc etc
    i've read the help file many times but my brain seems to go backwards everytime i read that,
    so i give up and let the real experts help out
    that's basically it
    thanks for the help and hope to hear from you soon
    Feb 2004
    Australia
    1: Same button multiple times using highlight to indicate where user is ... might be a little clustered
    2: Or use switched menu's ... more preferred method when using user images to indicate location but is a little slower when jumping between menu's.
    Dec 2003
    belgium
    Hey there
    thanks for the info, but could you explain a little more the second option?
    thanks
