  1. Hi guys,
    Im on a pc with cs5.5, 4 gb of ram and a nvidea 9500gt videocard and a quadcore...
    The playbavk and editting of my avchd material in premiere isnt very smoothly. Im looking to convert it to a format that premiere likes and lets me edit easily without being choppy...
    Ive looked at intermediate codecs, but their filesizes are huge! I want my file to be about the same as the source file... I have no problem with converting my material to a more compressed format e.g. Mp4/h264...but when i do that, playback still seems choppy....
    The bitrate of my avchd files is about 20mb i think, so if i kinda stick to that bitrate, quality loss will be acceptable right?
    Can anyone recommend a format that will meet my requierments and is easily edittable in premier?
    Apologies for my poor english, and thank you in advance...
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You need less compression not more. Gold standard for AVCHD is Cineform Neoscene + a large enough second drive.
    http://www.kiva.org/about
  3. Ok, but thats out of my budget right now....any alternatives? Thanks!
  4. Member edDV's Avatar
    Mar 2004
    For free there is the AVID DNxHD codec which is similar to MJPEG.
    http://en.wikipedia.org/wiki/DNxHD_codec
    http://www.avid.com/US/search?q=DNxHD+codec&x=18&y=8
    Also trusty old huffyuv.
  5. I have tried those, and they work fine indeed..the only problem is (forgot to mention this), is that I would like to see thumbnails for these video's in explorer and bridge...but that doesnt seem to be possible, does it?
  6. Member edDV's Avatar
    Mar 2004
    Don't know
    Sep 2008
    You may want to try AVC Intra. Getting rid of ther temperal information (B & P) frames might be enough to give you smooth playback.
    At least that way you still have small video files and it's a little easier for the PC to play it back.
    I have a Core 2 Quad @2.6GHz. With 4Gb of RAM (and it's only DDR2-800MHz) it couldn't do AVCHD. I bumped it up to 8Gb of RAM (still at a slow 800MHz) and it was a lot better. (I assigned 7.5Gb to Adobe programs)
    To help you a little more AVC Intra (which is AVCHD with only I-frames) will defintely take some CPU load off if that's the problem (vs available memory and hard disk speed).
    AVCHD will still give you .264/.m4v/.mts files which can be thumbnailed - thus why I thought of it for you.
    Apr 2003
    Just wanted to chime in - are you by any chance using a USB drive for your video files, because that can affect playback and editing in my experience? When I switched to eSata, then that solved my problem.
    Brainiac
