i am trying to convert mkv file into AVCHD format to use in my Panasonic Blu-Ray player
error happens in tsMuxer, on windows 7 it says tsMuxer stopped working
here is the conversion log from multiAVCHD, please help
[20:07:04] Initialising...
[20:07:04] Checking for new version...
[20:07:05] You have the latest build.
[20:07:05] Consistency check finished!
[20:07:05] Initialization finished. multiAVCHD is ready!
[20:07:05] 2 years and 326 days since multiAVCHD was published.
[20:07:05] 469 people supported it with donations
[20:07:05] and you are the 3565180 one to launch the program...
[20:07:05] Support multiAVCHD to extend its features and keep it going!
[20:07:05] multiAVCHD.dat version: [04010767]
[20:13:17] Checking for available space and drive types (FAT32/NTFS)...
[20:13:19] Destination [F:]: NTFS, 13028.83 MiB (12.723 GiB) free space
[20:13:19] Temp folder [c:]: NTFS, 40366.96 MiB (39.421 GiB) free space
[20:13:19] Log started for multiAVCHD v4.1 (build 770)
[20:13:19] Selected output mode: AVCHD compatible player (DVD/BD-R disc)
[20:13:19] Processing one title...
[20:13:19] Existing F:\AVCHD\ cannot be used as destination folder!
[20:13:19] Output will be written to: F:\AVCHD-20111117-201319
[20:13:19] Strict AVCHD folder mode is enabled...
[20:13:19] Processing (D:\Torrent Downloads\cars 2\cars 2.mkv)...
[20:13:19] This title is marked for reencoding / uncropping...
[20:13:19] Encoding process may take 10 min to 10 hours, so be patient...
[20:13:19] *** Initiating video encoding:
[20:13:19] *** Original : 1280x536
[20:13:19] *** Crop : 0
[20:13:19] *** Resize : 1280x536 (No change)
[20:13:19] *** Uncrop to : 1280x720
[20:13:19] *** Sharpen : 0
[20:13:19] *** Bitrate : 4219 kbps
[20:13:19] *** Frame rate: Original (23.976)
[20:13:19] *** Level : 4
[20:13:19] *** Quality : Two pass (high quality)
[20:13:19] *** SAR : 1:1
[20:13:19] *** DAR : 1280x720
[20:13:19] *** Profile : Blu-ray
[20:13:19] *** Encoding : Pass one - content: [01:46:55]
[20:13:19] *** Encoding : x264 options: --preset slow --tune film -B 4219 -p 1 --stats "c:\multiAVCHD\_TEMP\multiTEMP-20111117\x264-stats.txt" -I 48 --level 4 -i 4 -r 4 --mixed-refs -b 3 --weightb -m 2 -t 2 --qcomp 0.5 --merange 14 -A all --8x8dct --ipratio 1.1 --pbratio 1.1 --vbv-bufsize 15000 --vbv-maxrate 14000 --threads auto --thread-input --mvrange 511 --aud --nal-hrd vbr --sar 1:1 --b-pyramid strict --slices 0 --weightp 0 --qpfile "c:\multiAVCHD\_TEMP\multiTEMP-20111117\IDR-x264-marks.txt" --rc-lookahead 48 --no-mbtree -o NUL "c:\multiAVCHD\_TEMP\multiTEMP-20111117\20111117-201319-uncrop-running.avs"
[21:11:10] *** Speed P1 : 44.32 fps (elapsed: 00:57:50)
[21:11:10] *** Encoding : Pass two
[21:11:10] *** Encoding : x264 options: --preset slow --tune film -B 4219 -p 2 --stats "c:\multiAVCHD\_TEMP\multiTEMP-20111117\x264-stats.txt" -I 48 --level 4 -i 4 -r 4 --mixed-refs -b 3 --weightb -m 6 -t 2 --qcomp 0.5 --merange 14 -A all --8x8dct --ipratio 1.1 --pbratio 1.1 --vbv-bufsize 15000 --vbv-maxrate 14000 --threads auto --thread-input --mvrange 511 --aud --nal-hrd vbr --sar 1:1 --b-pyramid strict --slices 0 --weightp 0 --qpfile "c:\multiAVCHD\_TEMP\multiTEMP-20111117\IDR-x264-marks.txt" --rc-lookahead 48 --no-mbtree -o "c:\multiAVCHD\_TEMP\multiTEMP-20111117\cars 2.[1280x720-23.976].264" "c:\multiAVCHD\_TEMP\multiTEMP-20111117\20111117-201319-uncrop-running.avs"
[22:47:47] *** Close to completion - closing preview...
[22:56:15] *** Speed P2 : 24.39 fps (elapsed: 01:45:05)
[22:56:15] *** Speed : 15.73 fps overall (elapsed: 02:42:55 - Realtime x 0.66)
[22:56:15] *** Transcoding successful!
[22:56:16] Detected frame reference count: 3 (max:6).
[22:56:16] Detected video: ID#0:V_MPEG4/ISO/AVC 1280x720, fps=23.976, ref=3
[22:56:16] Detected audio: ID#2:A_DTS (48000Hz 16bit 6ch 1472kbps) Language: eng
[22:56:16] Added audio: A_DTS, "D:\Torrent Downloads\cars 2\cars 2.mkv", track=2, lang=eng, timeshift=0ms
[22:56:16] Converting TEXT subtitles to PGS/SUP...
[22:56:16] [cars 2.srt]
[22:56:32] *** 18 problems of all 10 are fixed!
[22:56:32] !!! Last imported subpicture: 1164/1164 at offset
[22:56:32] *** Imported subpictures: 1164/1164 at offset
[22:56:32] Conversion successful...
[22:56:32] Adding external subtitles (cars 2.srt) (ara)
[22:56:32] M2TS stream split set at 4000MiB...
[22:56:32] Creating clip and playlist info (tsMuxeR)...
tsMuxeR (Version 1.10.6) output:
Decoding H264 stream (track 1): Profile: High@4.0 Resolution: 1280:720p Frame rate: 23.9761
H.264 manual setted fps not equal stream fps. Change H.264 fps from 23.9761 to 23.976
tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000;00:08:54.590;00:17:49.180;00 :26:43.770;00:35:38.360;00:44:32.951;00:53:27.541; 01:02:22.131;01:11:16.721;01:20:11.312;01:29:05.90 2;01:38:00.492 --split-size=4000MiB --vbv-len=500
V_MPEG4/ISO/AVC, "c:\multiAVCHD\_TEMP\multiTEMP-20111117\cars 2.[1280x720-23.976].264", insertSEI, contSPS, lang=eng, fps=23.976
S_HDMV/PGS, "c:\multiAVCHD\_TEMP\multiTEMP-20111117\srt-339975724.ara.sup", lang=ara, fps=23.976
[23:24:10] Important files missing (clpi/mpls/m2ts)...
[23:24:10] Possible tsMuxeR failure to process your input file (D:\Torrent Downloads\cars 2\cars 2.mkv).
[23:24:10] M2TS (media) file count: 0
[23:24:10] CLPI (clipinfo) file count: 0
[23:24:10] MPLS (playlist) file count: 0
[23:24:10] Skipping to next...
[23:24:10] ERROR: Compilation does not contain any HD-DVD/AVCHD/Blu-ray titles!
[23:24:10] Setting pop-up menu...
[23:24:10] *** Completed!
[23:24:10] Preparing menu pages...
[23:24:10] Setting main menu for 0 titles...
[23:24:10] Selected TV system: [PAL]
[23:24:18] Done!
Compilation summary:
Format: AVCHD compatible player (DVD/BD-R disc)
Output size : 0 MiB (0 GiB)
[23:24:18] Warnings/errors for this compilation: 1
[23:24:18] F:\AVCHD-20111117-201319 folder created (AVCHD/Blu-ray output)!
[23:24:18] Burn its CONTENTS to DVD R/RW UDF 2.50/2.60 disc!
[23:24:19] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20111117\).
[23:24:19] multiAVCHD finished in 11460.473 seconds (03:11:00.472)!
[23:24:19] End of log.
[23:24:19] Cleaning up...
[23:24:20] Done!
[23:24:21] For technical support, bug reports and questions:
[23:24:21] http://multiFORUM.deanBG.com/
[23:24:21] http://multiAVCHD.deanBG.com/
[23:24:21] http://multiAVCHD.deanBG.com/doom9/
[23:24:21] For latest download links and tools visit:
[23:24:21] http://multiFORUM.deanBG.com/downloads/
Closed Thread
i have found this to be one of 2 problems:
1. the mkv was muxed with header compression
2. there is an error in the audio file.
i would:
1. remux the .mkv in mkvmerge and diszble header compression for every stream (video, audio and subtitles).
2. then try and open the mkv in tsmuxer. if it opens fine then you are good to go with multiAVCHD. if not, then the audio file needs to be "fixed" or re-rip the audio from the original BD.
EDIT: also, i would make sure my destination folder had enough free space. 13 GB isn't a good idea.
Problem with multiAVCHD...
By hiimbored in forum Authoring (Blu-ray)Replies: 7Last Post: 2nd Jun 2015, 11:14 -
Problem remuxing with multiAVCHD
By jadasneez in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jan 2012, 17:08 -
MultiavcHD menu problem...HELP!
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 07:06 -
multiAVCHD syncing problem
By dan_man555 in forum Video ConversionReplies: 6Last Post: 30th Jun 2011, 22:41 -
Is multiavchd a problem?
By volam1 in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Oct 2009, 16:19
