I have been using freemake converter for a while to covert to dvd and burn my home movies.
I takes roughfly 10 to 12 minutes from start to finsh. (approx 150 minutes of Video)
I am completey happy with the quality and every other feature.
Question can any one recommend another "converter" free or "not" that is faster and easy to use>
i have tryied ConvertXtoDVD 4 simple to use but take about 30 minutes
Results 1 to 20 of 20
Never tried it myself, and (currently) it hasn't been updated in over 2 years, but DVD Flick is free.
But as you said, you're completely happy with Freemake
The quality is great
Just looking for a faster converter program
"Flv to dvd and burn the disk" in less time than mentioned aboveLast edited by gaggymitchell; 17th Nov 2011 at 17:24. Reason: clarification
Should i post this question in another erea of the forum for the answer (Newbie)
thanks However i am open to any converter that is faster than fremake ie free downloads or ones that you have to buy.
All in all i guess fremake converter at 10-15 minutes to convert and burn a dvd is a descent time for the quality i have been getting.
Maybe i am asking for to much? -
There might be a faster program if you are just moving the video and audio to a different container without converting to another codec, but 10 to 12 minutes is fast for any other kind of conversion (to a different codec) or for DVD authoring. I doubt that you can do better if you are doing either of those things.
fremake converter took 11 minutes 4 seconds to convert and burn
convertXtodvd 4 took 16 minutes 30 seconds to convert and burn A little better quality but not much than freemake
DVD FLICK I will download and try it next
So far freemake is the fastest and free (flv to dvd, burn dvd and then let you play in television dvdplayer)My thoughts only -
To just burn a full ( 4.7 GB) DVD on my box takes 7 minutes @ 12x.
Are you using a Cray Supercomputer to do your encodes? -
To convert "FLV TO DVD" and "Burn" a full ( 4.7 GB) DVD on my box takes about 11 minutes @ 12x
using the above mentioned software.
Whats your time if you have ever gone they way i mention here and what software do you run to accomplish this
Thanks In advance -
I love it when a plan comes together!
thanks i will try the one you suggest next
Trying to use dvd flick right now to check speed and quality however it says it doesnt not recconize my flv files that i downloaded with real player so far convertXtodvd 4 and fremake had no problem with these , but dvd flick does must be something i am missing? -
Thanks a lot that will save me some time. i will try another thanks a bunch!
I was wondering if you folks no if the purchased version of convertXtodvd 4 was faster than the free trial version?
freemake converter took 11 minutes 4 seconds to convert and burn
convertXtodvd 4 took 16 minutes 30 seconds to convert and burn A little better quality but not much than freemake -
When I use Freemake Video Converter, it only seems to convert to about 22 or 23 minutes. It says it's complete but none of the 6 files I've tried complete to the end. In fact, after I add the video and choose the format to convert, it even shows the size of the show to only be 22 ish minutes. Anyone else run into this?
Crappy/corrupt source? Maybe badly joined so it only sees the first joined file for example.
But I don't see what that has do with this thread...fastest video to dvd converter...
freemake video converter mp4 to mkv
By rushy7 in forum Video ConversionReplies: 13Last Post: 12th Mar 2012, 13:11 -
looking for help from those using 'freemake'
By alphabetagaga in forum DVD RippingReplies: 5Last Post: 14th Jan 2012, 08:13 -
Freemake Video Converter: How To Ensure CBR Audio?
By Tom Saurus in forum Video ConversionReplies: 1Last Post: 21st Aug 2011, 14:41 -
Freemake puzzler...
By mjl1297 in forum Video ConversionReplies: 3Last Post: 1st Aug 2011, 22:30 -
Freemake Converter Doesn't Accept swf Video
By rckowal in forum Video Streaming DownloadingReplies: 4Last Post: 25th Dec 2010, 16:10
