Closed Thread
Results 1 to 9 of 9
That depends on whether or not you wish to provide more details on EVERYTHING you did to create that BD disc.
Imagine that we have a car repair shop. This is what you THINK you are telling us with your post:
I haven't had brake work done in years. My car squeals every time I hit the breaks. The brakes don't seem to be working very well and I'm smelling a little burned smell when I hit the brakes. Can you please check the brakes?
What you have ACTUALLY told us with your post:
I've got a problem with my car and I'm not going to tell you what it is but I expect you to fix it.
Provide a lot more details if you really want help.
K sorry xD
I have a bluray1080p movie on my PC with format .mkv. I want to watch it on my TV.
I learned on the internet i first had to make the .mkv into 2 folders, BDMV and CERTIFICATE. I muxed the .mkv file with tsmuxer.
When i watch this movie on my pc it replays fine.
Secondly i burned the 2 folders on a rewritable BD from Sony with 25 GB. I did this with Imgburn but also with Windows 7.
When i put the BD in my Bluray Player, LG BD370, it shows the screenshots i submitted.
When i put the BD in my TV it replays fine.
The video looks re-compressed to very low bit rate.
http://www.kiva.org/about
Check post #42 in
https://forum.videohelp.com/threads/340545-How-to-play-HD-Video-from-Hard-Drive-to-Blur...49#post2120649
for basics.
What is your folder structure and media spec? Use mediainfo.Recommends: Kiva.org - Loans that change lives.
TV is 42LE5500.
Algemeen
Complete name : E:\Downloads\Films\Films\HD\Transformers
Format : Blu-ray movie
Duration : 2h 34mn
Overall bit rate mode : Variabel
Overall bit rate : 0
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Ja
Format settings, ReFrames : 5 frames
Codec ID : 27
Duration : 2h 34mn
Bit rate mode : Variabel
Bit rate : 8 475 Kbps
Maximum bit rate : 40,0 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2,40:1
Frame rate : 23,976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Stream size : 9,26 GiB (89%)
Writing library : x264 core 118 r2085 8a62835
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8475 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.0
Language : Engels
Source : 00000.m2ts
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 2h 34mn
Sampling rate : 48,0 KHz
Language : Engels
Menu
That is the MediaInfo from the BDMV folder+ CERTIFICATE.
it doesn't look like it was authored to blu-ray spec. unless you have a special TV that is meant to display movies with an AR of 2.40:1, you should have black bars on the top and bottom.
if the movie was from a .mkv then you need to re-encode it to blu-ray spec (uncrop to 1920x1080...i use multiAVCHD...but there are different ways to skin that cat).
Help - Y wont my burned movie play
By sweetcheeks82 in forum DVD RippingReplies: 4Last Post: 18th Aug 2011, 14:37 -
dvd's I burned do not always play on television
By geminidreamer in forum Newbie / General discussionsReplies: 6Last Post: 14th Nov 2009, 19:29 -
Can't play burned DVDs - In need of some serious help!!
By fustrated in forum DVD & Blu-ray PlayersReplies: 13Last Post: 7th Jun 2008, 12:18 -
Burned DVDs only play on my computer
By kissy in forum Newbie / General discussionsReplies: 16Last Post: 7th Jan 2008, 13:48 -
want to play burned cd in my car
By terrie29 in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2007, 02:55
