I've tried several different programs/methods and with each result, the audio becomes out of sync toward the end when I attempt to trim the length. Avidemux will seemingly handle most other video formats/etc but nothing seems to work with these. Has anyone had success with this?
Are you cutting inside the GOP? or on I (key) frames?
flv files aren't designed for editing, have long GOPs and some variable frame rates. Easy to break audio sync.
You will have to manually resync on a timeline editor.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'd decode to MJPEG+PCM audio and put it on a Vegas or Premiere timeline then slip the audio vs video to resync. It may be necessary to speed or slow the audio to various marked critical lip-sync scenes. When finished, re-encode.
Is there ANYthing that will trim h.264 flv's without audio sync issues?
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 29th Mar 2012, 10:07 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 12:51 -
Seeking audio sync using avisynth trim and selectRange
By Kab09 in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2009, 13:10 -
App to trim .flv files?
By brassplyer in forum Video Streaming DownloadingReplies: 1Last Post: 13th May 2008, 02:33 -
single .vob in ffmpegX to h.264 (mencoder) .mp4 a/v sync issues
By jabroni5 in forum ffmpegX general discussionReplies: 15Last Post: 7th Jun 2007, 17:48
