Help-
Is it possible to re-create a playlist, use another cam's playlist, or software to recombine all .mts files in a directory into a seamless stream?
I copied the .mts files from "STREAM" and the .cpi files from "CLIPINFO" but forgot the .mpl files from "PLAYLIST" when making an archive.
How can I re-combines the 7 .mts files into one video without gaps?
Thanks-
	Thanks wulf109
 So i have tried demuxing the 7 .mts files with TSmuxer set not to split... but i still get lots of files on output that vegas doesn't want to import as a single video clip.
 Next I created a .ts file, that vegas and VLC just crashed on loading, then i tried the "AVCHD disk" option, that vegas found no video inside, and vlc crashed upon trying to play the 15GB file.
 I feel like i wasted a day trying this out, because nothing worked.
 I would appreciate any further instruction to get my .mts files into a single video clip I can edit with.
 anD
	I want to get the 7 2gb .mts files that were part of a single 2 hr video on my canon vixia hf s20 to load into my video editor (vegas) as a single video clip. Apparently vegas needs the playlist files (missing) to recombine the .mts files into a seamless clip.
 I hit "join" this time instead of dragging the files in. it seemed to join them last time in output... I just want something I can get IN to vegas without the gaps that happen by dragging the short 2GB .mts files in directly.
	Right - it drops 3 to 7 frames worth when it doesn't have the playlist files in the avchd structure to help with recombination and timing.
	Using "JOIN" in tsmuxer and setting output to "AVCHD disk" the vegas "device browser" will recognize the directory structure but it fails to see the clip.
 This is because the clip from tsmuxer is output as .m2ts instead of .mts - So, from here that .m2ts file can be dragged directly onto the vegas timeline. Easy as pie. The best news of all is that tsmuxer joins the video properly compensating for whatever happens when the camera switches to a new .mts file every 2 gigs. My video streams that were missing the playlist info line up with those imported directly from other cards and cameras throughout the project. Thanks wulf109.
  AVCHD - join MTS filesBy cmichel04 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 11th Nov 2012, 18:30
  Help seamlessly re-combining .mts files without a playlistBy and in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Nov 2011, 14:08
  Join mts video and convert to ts formatBy Benkh in forum Video ConversionReplies: 7Last Post: 17th Aug 2010, 08:14
  Simple way to join mts files with stream copy (no recoding)?By MJ Peg in forum Video ConversionReplies: 32Last Post: 1st Oct 2009, 08:29
  .vob player that can create playlist/queueBy dannieboiz in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2008, 19:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
