I was using CamStudio to record a training class. I went back into the room at the end of the day and the software had crashed. I'm guessing because it was recording for 8 hours. I have two temporary files on my computer one for the video and one for the audio. The file size is a little over 4GB. Is this video and audio lost or is there anyway I can make it so that it can be played. For today's training class I'm using camtasia and I'm going in there every few hours and saving the video so I don't have any problems.
The temp files probably are the missing video/audio.
Whether you'll ever get them to play is another thing entirely.
Have you tried renaming them with the proper file extension - eg. video.avi ? -
Perhaps the index is missing. Try opening it in Virtualdub. On the file/open screen select "extended options"
and choose redrive keyframes on the next screen.
If still no-go, see what you can find at their site and/or contact the author:
http://www.techsmith.com/support.html
Re-encode audio but keep video the same in MKV file
By V879 in forum Video ConversionReplies: 3Last Post: 15th Apr 2012, 08:51 -
Freeware to encode to WMV (w-WMA audio) video?
By Diana (Cda) in forum Video ConversionReplies: 6Last Post: 6th Jan 2012, 12:19 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 15:07 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 09:20 -
No Audio after encode quicktime video in flash 8
By yunakokimama in forum MacReplies: 3Last Post: 11th Dec 2007, 20:07
