  1. Hello,
    I am brand new to this forum and the reason for my post is to ask the members if there is a way to extract just the text from a .caption file? Below is an example of one of the .caption files I am referring to. I have highlighted in green some of the text that I am talking about.
    This .caption file is from a tutorial dvd and I want to be able to print the captions out on paper so that I can refer to them while studying the tutorials.
    Would anyone be able to recommend a software/editor that can do this?
    Thanks!
    Dan
    <?xml version="1.0" encoding="UTF-8"?>
    <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
    <plist version="1.0">
    <array>
    <dict>
    <key>in</key>
    <real>0.0</real>
    <key>out</key>
    <real>3.1600000000000001</real>
    <key>text</key>
    <string>(Music playing.)</string>
    <key>text2</key>
    <string></string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>7.1066666666666665</real>
    <key>text</key>
    <string>Hi! and welcome </string>
    <key>text2</key>
    <string>to Pro Tools 8: Mixing and Mastering.</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>11.031666666666666</real>
    <key>text</key>
    <string>In this course, I'll show you how to </string>
    <key>text2</key>
    <string>take your projects to the next level using</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>16.018333333333334</real>
    <key>text</key>
    <string>Pro Tools 8, tying all the pieces </string>
    <key>text2</key>
    <string>together into a killer-sounding mix.</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>20.078333333333333</real>
    <key>text</key>
    <string>Together, we'll explore the Pro Tools </string>
    <key>text2</key>
    <string>Mixer and understand the basics of signal flow, </string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>24.008333333333333</real>
    <key>text</key>
    <string>plug-ins, effects returns and submixing.</string>
    <key>text2</key>
    <string></string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>27.098333333333333</real>
    <key>text</key>
    <string>I'll discuss the importance of </string>
    <key>text2</key>
    <string>setting up a solid mixing plan and give you</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>30.153333333333332</real>
    <key>text</key>
    <string>advice on working through </string>
    <key>text2</key>
    <string>the critical stages of the mix.</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>35.038333333333334</real>
    <key>text</key>
    <string>I'll cover the basic mixing tools every </string>
    <key>text2</key>
    <string>producer should know, from using EQ to</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>40.071666666666665</real>
    <key>text</key>
    <string>add clarity and focus to effectively </string>
    <key>text2</key>
    <string>using dynamics processors to add impact and</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>42.024999999999999</real>
    <key>text</key>
    <string>power to your mixes.</string>
    <key>text2</key>
    <string></string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>46.00333333333333</real>
    <key>text</key>
    <string>I'll explain how to achieve that </string>
    <key>text2</key>
    <string>commercial radio-ready sound during the</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>51.008333333333333</real>
    <key>text</key>
    <string>mastering stage, by using compression and </string>
    <key>text2</key>
    <string>limiting to maximize the level of your mix.</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>54.043333333333337</real>
    <key>text</key>
    <string>If you're new to Pro Tools, you </string>
    <key>text2</key>
    <string>should definitely check out the Pro Tools 8</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>57.101666666666667</real>
    <key>text</key>
    <string>Essential Training course here </string>
    <key>text2</key>
    <string>on the Online Training Library.</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>61</real>
    <key>text</key>
    <string>But if you're already familiar with the </string>
    <key>text2</key>
    <string>basics, I'll share some great tips I've</string>
    </dict>
    <dict>
    <key>in</key>
    <real>61</real>
    <key>out</key>
    <real>65.010000000000005</real>
    <key>text</key>
    <string>learned from my five years as a </string>
    <key>text2</key>
    <string>Digidesign Certified Expert Instructor and over</string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>66.153333333333336</real>
    <key>text</key>
    <string>ten years of mixing in the box.</string>
    <key>text2</key>
    <string></string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>68.155000000000001</real>
    <key>text</key>
    <string>So if you're ready, I'm ready.</string>
    <key>text2</key>
    <string></string>
    </dict>
    <dict>
    <key>in</key>
    <key>out</key>
    <real>71.151666666666671</real>
    <key>text</key>
    <string>Let's get started with Pro </string>
    <key>text2</key>
    <string>Tools 8: Mixing and Mastering.</string>
    </dict>
    </array>
    </plist>
    Strip the tags and then edit manually in your favorite text editor,
    in
    0.0
    out
    3.1600000000000001
    text
    (Music playing.)
    text2
    in
    3.1600000000000001
    out
    7.1066666666666665
    text
    Hi! and welcome
    text2
    in
    7.1066666666666665
    out
    11.031666666666666
    text
    text2
    in
    11.031666666666666
    out
    16.018333333333334
    text
    text2
    in
    16.018333333333334
    out
    20.078333333333333
    text
    text2
    in
    20.078333333333333
    out
    24.008333333333333
    text
    text2
    in
    24.008333333333333
    out
    27.098333333333333
    text
    text2
    in
    27.098333333333333
    out
    30.153333333333332
    text
    text2
    in
    30.153333333333332
    out
    35.038333333333334
    text
    text2
    in
    35.038333333333334
    out
    40.071666666666665
    text
    text2
    in
    40.071666666666665
    out
    42.024999999999999
    text
    text2
    in
    42.024999999999999
    out
    46.00333333333333
    text
    text2
    in
    46.00333333333333
    out
    51.008333333333333
    text
    text2
    in
    51.008333333333333
    out
    54.043333333333337
    text
    text2
    in
    54.043333333333337
    out
    57.101666666666667
    text
    text2
    in
    57.101666666666667
    out
    61
    text
    text2
    in
    61
    out
    65.010000000000005
    text
    text2
    in
    65.010000000000005
    out
    66.153333333333336
    text
    text2
    in
    66.153333333333336
    out
    68.155000000000001
    text
    text2
    in
    68.155000000000001
    out
    71.151666666666671
    text
    text2
  3. Thanks Baldrick,
    As some of these files are quite large I was thinking about using my editor (TextPad) which supports regular expressions. Would you know of how to write a regular expression that would delete the specified tag and eveything in between. For example: <key>in</key> Find <key> and </key> and eliminate the tags and everything in between.
    Thanks,
    Dan
    Jul 2011
    Denmark
    Hi Dan, you could try latest test version of SubtitleEdit - http://www.nikse.dk/SubtitleEdit.zip
    Use File -> Export -> Plain text
