Here is the situation.
I obtained about 300-350 avi(xvid) videos which resolution is 720x576.
However aspect ratio is 5/4 and is WRONG and should be 4/3.
So I see two solutions to correct it:
1) In VirtualDub resize them to proper 4/3 aspect ratio so 720x540 resolution. This requires Full Processing mode and about ~1h per one video (single pass) but I can queue jobs and run them when I want.
2) Load each video in MPEG4 Modifier and change aspect ratio to 4/3. This requires no conversion but no queue is available (emailed the author of the program about possible update but no answer)
Which solution is BETTER ?Or maybe you come up with another?
MPEG4Modifier. Check and see if there's a CLI option, as you could script a batch file to take care of them altogether...
Scott -
There is a command line version with an example for batch conversion.
http://forum.doom9.org/showpost.php?p=893015&postcount=1 -
I concur, MPEG4Modifier will do the job nicely.
autogk wrong aspect ratio
By codemaster in forum Video ConversionReplies: 8Last Post: 5th Feb 2011, 10:09 -
Wrong Aspect Ratio
By weathervane in forum Capturing and VCRReplies: 11Last Post: 18th Aug 2010, 23:18 -
wrong aspect ratio using ripbot
By magmo in forum Video ConversionReplies: 2Last Post: 12th Mar 2009, 09:15 -
Fixing wrong aspect ratio.
By mattstan in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 15:17 -
wrong aspect ratio ???
By clickit in forum ComputerReplies: 3Last Post: 7th Dec 2007, 03:49
