Hi
I have four files which together (seem to) make up one mp4 file. The first file plays fine on VLC, but only up until a point (1/4 of the vid), while the other three seem to be unplayable. I've tried to merge/append them using Avidemux and YAMB, but no success.
Is there a way to combine the four files to make up the video as a whole?
Thanks!
You could try join them with a file joiner like hjsplit, http://www.hjsplit.org/windows/ , and see how it works.
If that wont help then what happens when you try avidemux or yamb? -
I tried hj-join, but still no luck. the files even have the .001, .002, .003 layout that hj-join requires, which made me think it would work, but no dice.
With avidemux I get an error when trying to append the 2nd/3rd/4th files to the first one. only the first file will open.
With YAMB I can line up the files to merge, but once I hit "Join" it gives me an error message re MP4Box crashing.
Is there a guide to merging multiple DVD titles into a single output file?
By Lolipop Jones in forum DVD RippingReplies: 10Last Post: 11th Nov 2016, 19:19 -
how to merge multiple mp4 into 1 file
By carlos28355 in forum Newbie / General discussionsReplies: 6Last Post: 25th Oct 2012, 08:29 -
Merging multiple files as one video file?
By mikehende in forum Newbie / General discussionsReplies: 5Last Post: 10th Nov 2011, 06:28 -
Split mp4 file into 10 minutes parts in order to upload on youtube
By vitcon in forum ComputerReplies: 4Last Post: 11th Mar 2011, 13:30 -
Converting Multiple Chapter DVDs into one single MP4 file
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 13:02
