Hey guys, nice to meet you all
I am trying to understand how this all works.
I have converted an MKV file to Bluray using TSmuxer so that I could burn it onto a BD and play on my standalone Bluray player. It all seems to have worked and plays on my player but to me appears no different then an ordinary DVD. I was also surprised that the file is no bigger then the MKV file. I was under the impression by converting to Bluray it would be a massive file and therefore give me the HD quality.
Any help would be really appreciated, thanks.
Results 1 to 10 of 10
1) Upconverting the resolution will *not* give you HD quality. You're stuck with what you started with. Might as well let your HDTV do the upconverting.
2) You didn't re-encode the resolution in any case; tsMuxer can't do that. You re-packaged the file; i.e. the contents are still the same, different package.
3) You didn't specify, but I presume this is an MKV made from a DVD. Therefore standard resolution (SD). You can get the particulars with MediaInfo and post them here.
4) And welcome to the forum.Pull! Bang! Darn! -
Thanks...here are details as follows:
General
Unique ID : 193952070835471502887458916873769945754 (0x91E9CF62B33D88268306071C12B98A9A)
Complete name : D:\Downloads\Another Earth\ArEh11\ArEh11.mkv
Format : Matroska
Format version : Version 2
File size : 697 MiB
Duration : 1h 32mn
Overall bit rate : 1 054 Kbps
Encoded date : UTC 2011-10-29 03:43:19
Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Video
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 32mn
Bit rate : 863 Kbps
Width : 720 pixels
Height : 384 pixels
Display aspect ratio : 1.875
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.130
Stream size : 556 MiB (80%)
Writing library : x264 core 119 r2106 07efeb4
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=863 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 32mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 127 MiB (18%)
Default : Yes
Forced : No -
Your source is just DVD/SD quality so you can't get any Blu-ray/HD quality as fritz already mention.
Buy http://www.amazon.com/Another-Earth-Two-Disc-Blu-ray-Digital/dp/B005LZW8FO/ref=sr_1_1?...1453562&sr=1-1 ... -
Bit rate : 863 Kbps <---- actually much less than DVD quality at that bit rate.
Width : 720 pixels
Height : 384 pixelsRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hello all... I have a question. What if my original source is HD quality and is a mkv format... When I try to convert mkv to a bluray which is BDMV, and Certificate and can hear audio but no video. Can someone help me what I am doing wrong here with converting in TSmuxer. Thanks.
Blu-ray players are extremely picky about what they will play. You usually need to stick with standard Blu-ray resolutions and h.264 properties.
Also, just a quick note about mkv. The bitrate of 863 is incredibly tiny for any video type, however I have found that with mkv the picture quality is far superior at 863 kbps then if you used just a regular mpg container format. I think this has to do with the mkv format itself? And the way it uses compression?
my converted MKV to Bluray is not workin
By obadvw in forum Authoring (Blu-ray)Replies: 5Last Post: 30th Oct 2011, 03:18 -
playing dvd converted to mkv on bluray
By bkstaff in forum Video ConversionReplies: 2Last Post: 5th Jun 2011, 20:59 -
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 04:42 -
bluray 3-d to mkv?
By dave_o in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2010, 08:38 -
Wrong resolution/framerate on mkv converted to bluray with TsMuxer
By tomamitai in forum Video ConversionReplies: 2Last Post: 30th Mar 2009, 04:13
