I am currently making script, which will automatically reencode mkv files to flv with lower bitrate. I am having problems with files, which contain audio tracks, which were for example taken from DVD and are made for different fps, usually 25. So stretching was used while muxing the original mkv. When I run my script automatically the audio is out of sync as it does not recognize, that the audio was made for 25 fps video instead of 23.967 fps. It works fine when I set at MP4Box manually fps of audio for the flv muxing, but which tool to use to recognize it automatically? Mediainfo shows 23.967 fps for both video and audio, but it should rather show 25 fps for the audio. Is there any tool, which would recognize muxing parameters used while creating the original mkv?
Try mkvinfo (included in mkvtoolnix) and see if it lists some more detailed info.
muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
By codemaster in forum Video ConversionReplies: 2Last Post: 20th Sep 2011, 21:50 -
Muxing MKV file with mmg (mkvmerge)
By HAL4711 in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2009, 19:49 -
MKV Muxing Audio Out-of-Sync with Video
By Cube11 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2008, 14:27 -
Is there a way to find your registration details?
By Nitro89 in forum ComputerReplies: 3Last Post: 19th May 2008, 11:20 -
mkv file audio muxing problem
By shun in forum EditingReplies: 2Last Post: 23rd Feb 2008, 09:15
