I've got a matrox g400Tv capture card, and am having problems recording above 352x288 without strange interlacing problems. It was suggested that I try to capture with HUFFYUV codec instead of the matrox MJPEG compression and try using the 'swap fields' option in virtualDub, but I can't seem to get it to work without a massive frame loss, even on the lowest quality settings with my 1GHz Athlon. I've read about RGB and YUY (but don't really get it!) and note that HUFFYUV uses YUY in some way, but my card drivers won't let me set my video format to YUY (only RGB or MJPEG).
Any ideas guys??
Many thanks![]()
Results 1 to 1 of 1
Huffy codec and field threshold
By TaranScorp in forum Capturing and VCRReplies: 7Last Post: 5th May 2011, 14:56 -
Captured huffy AVI, convert to mpg poor.
By davexnet in forum Video ConversionReplies: 19Last Post: 15th Jul 2010, 22:01 -
huffy -> xvid
By geonuine in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 3rd Nov 2008, 08:49 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 18:52 -
Problem exporting a file with HUFFY UV
By V.A.M in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 19:53
