Results 1 to 30 of 31
  1. i am edditng with premiere cs3 and i am one of those that can't play the video real time due to low buget video card and low birate hard drive. So i am looking to encode the .avi file to something mpeg2,xvid,.... or something the fastest way so i can playback the result.
    rendering a 6 min timeline into mpge2 through MainConcept codec takes 8 hours. only cropping and and convert to black n white.
    so i want to frameserve from cs3 to something (maybe vdub) and encode it to a diffent format. i dont care about the image quality and loss. and i dont care about what the ouput format will be.
    i am considering thought about not loosing frames and jerking effects.
    so which is the fastest encoder .avi ----> something else
    that will playback correctly?
    give me your lights!
    PC specs: Intel Pendium 4, CPU 3GHz, 2G RAM
  2. Divx with it's realtime setting. x264 with it's Ultrafast and Veryfast presets. PicVideo MJPEG.
    8 hours for 6 minutes video? Something must be wrong...is it 1080p HD? or HIGHER?
  4. buy second HDD, render file to different HDD, defragment HDD - seems that You have problems with computer not with codec (and yes, MJPEG seems to be fastest codec)
  5. DECEASED
    Jun 2009
    Heaven
    Another possibility --- a "stubborn" process / application is running in the background and it's interfering with the video editor/encoder
    Run "taskmgr" and see what it reports
  6. ""stubborn" process / application" like anti-virus software checking HDD activity - i saw few times such configuration... (even worse - a few anti-virus software's active at the same time, concurring each other...)
  7. guys thanks a lot for helping me out here..
    i made some tests..
    i made a format windows xp professional
    i disable all the automated start-up programms
    i disable avira antivirus
    i made a defragmentations with the windows software (by the way, when defragmentation finished gave me a message that process complite but some places of the disk couldn't de defraged
    and i rendered a 1 min timeline (filtering used: black n white, crop, brightness and contrust) in 30min
    hd 1080i25
    premiere project settings :video rendering -->maximum bit deapth unchecked
    adobe media encoder settings: minimum bit rate :7
    target bit rate :8
    maximum bit rate :9
    1 pass
    quality 4/5
    no noise redution used
    no deiterlace
    pc specs: Pentium 4 CPU 3.00GHz, 2G RAM
    HDD WDC WD800JB-00JJA0 ---->
    Manufacturer: Western Digital
    Model: WD800JB-00JJA0
    Layout: 3.5 inches - Desktop
    Interface: IDE 40PIN DESKTOP
    Capacity: 80.0 GB
    LBA : 156301488
    Family: WD Caviar
    WD P/N: WD800JB-00JJA0
    DCM: DSBHYAJCH
    Speed: 7200 RPM
    Seek Time: 8.9 ms (Average)
    Buffer: 8 MB
    and one HDD WD external usb interface , i dont use this one.
    windows xp prof servise pack3 all updates done.
  8. taskmgr upload
  9. still very long IMHO - for defragmentation You can use one of freeware programs - like MyDefrag http://www.mydefrag.com/ but there is few more defragmenters worth to consider http://www.techradar.com/news/software/applications/6-of-the-best-defrag-software-downloads-668176
    check unused services, check firewall (i use one of the best - kerio 2.1.5 - old but fast and reliable, reduce amount active apps, turn off wallpapers, animated cursors etc) You will see difference after going for very simple interface on memory and CPU use.
    use CCleaner to remove unnecessary autostarting apps and various garbage files
    also read this:
    http://www.mydefrag.com/Manual-TipsAndTricks.html
  10. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    What is the codec for this 1080i25 source file? Does your Premiere project setting match the source format?
    Your CPU is weak for HD editing. You need a second internal drive for performance. Put the scratch file and media on the second drive.
    When you say "i am one of those that can't play the video real time", do you mean the source file? The Premiere timeline preview? or the encoded result? Is the goal to speed timeline performance or just to play the resulting encoded file outside Premiere?
    http://www.kiva.org/about
  11. Originally Posted by edDV View Post
    any modern CPU is to weak for HD editing (HD editing is a bit fuzzy concept)
    P4 is acceptable (not for real time but anyway not so bad - i would say that 486 or Pentium III can be to slow but P4 should be capable to decode 1080i30 MPEG-2 in real time ie it is sufficient to home HD editing )
  12. Your options are to get a more powerful computer or use a faster codec and/or faster codec settings. Faster settings will get you lower quality.
  13. edDy i know that to speed premiere timeline perfomance i will need a new video card and more CPU. which i wont intent.
    so i am trying to speed the time needed to see the result which is at first level. before all the aesthetic filtering.
    source file = premiere stetting= 1080i25 HDV
    pandy i will try the other Defragmentation softwares, and cc cleanen
    i have the minimun apps running
    is a new HDD going to solve the problem of rendering time? 1min timeline ---->30min
    which are the eficient HDD specifications needed?
  14. Make sure your hard disk is set to UltraDMA...
  15. Separate HDD for sure will help, specification is less important (however go for at least 1TB HDD - high capacity imply high internal transfer rate and less mechanical activity which always is SLOW - also You can think about small SSD for SYSTEM - hard to say however - i always have separate partition for system which is up to 16GB - small SSD cost now around 35 - 45E for 16 - 30GB size) - probably any modern HDD will be faster than a bit old 80GB HDD - I hope that Your motherboard support SATA
    Or there is no problem with HDD (signaled as yellow triangle in disk manager) - run on command line:
    "chkdsk c: /f /r"
    (repeat this for all disks/partitions in computer)
    more in http://support.microsoft.com/kb/315265
  16. Originally Posted by cd090580 View Post
    ultra dma mode 5
  17. comant results
    The type of the file system is NTFS.
    Cannot lock current drive.
    Chkdsk cannot run because the volume is in use by another
    process. Would you like to schedule this volume to be
    checked the next time the system restarts? (Y/N)
  18. Originally Posted by gyzel01 View Post
    Those won't help.
    No.
  19. Originally Posted by pandy View Post
    A drive which has fallen out of DMA and is resorting to PIO will not show as a problem in Device Manager. You have to go to the device properties and see if it is in DMA or PIO mode.
    If you're saving as h.264 that's probably about normal for a P4.
  20. Originally Posted by jagabo View Post
    Those won't help.
    No.
    Unless you are performing heavy duty rendering almost all the time is being spent in the encoder.
    which rendering is heavy duty, can you give me an example please?
  21. Originally Posted by gyzel01 View Post
    Those won't help.
    No.
    Sorry, I was editing and screwed up. I meant to say:
    Unless you are performing heavy duty filtering almost all the time is being spent in the encoder.
    Heavy duty filtering would be things like motion compensated noise reduction or deinterlacing. You stilll haven't said what codec you were using (Mainconcept has more than one) with that long encode. Was your output HDV? h.264?
  22. ok. my source format is HDV 1080i25 not AVS. trying to encode to mpeg2 using MMC,Procoder...
  23. Originally Posted by gyzel01 View Post
    comant results
    answer Y, reboot, wait (can be long to finish checking HDD)
    Those won't help.
    Can help if source and final files are spreded over HDD surface thus R/W is not sequential - original defrag have serious problem to deal with this - reordering files, consolidation, make large block for write can improve performance seriously.
    No.
    it should help - sequential reading from one HDD, sequential wiriting to second HDD (HDD buffers used) can improve performance - also access to system files reduce performance - with 2GB RAM swap file shall be permanent type and fixed size to avoid fragmentation.
  24. quote fever!!!!! completelly messed up
  25. Member edDV's Avatar
    Mar 2004
    Maybe a dual core P4 but I just tried to play an HDV file in a P4 2.8GHz software only with VLC and it couldn't keep up with 1x play. It will play with a GPU assisted NVidia PureVideo display card.
  26. check ffmpeg, MPC, ffdshow, pure decoding is real time and CPU utilization was AFAIR around 60 - 80%
    VLC can render RGB - color space conversion can be performed by graphic card (even old one without fancy GPU)
    I have P4 3.2GHz in home - i will try to check this today.
  27. Originally Posted by pandy View Post
    comant results
    Those won't help.
    No.
    Yes, he will save a few seconds off his 8 hour rendering time. HDV in and MPEG 2 out (HDV again?) is very little disk I/O. Less than 2GB of reads, and probably even less for the writes, isn't the cause an 8 hour rendering time.
  28. Originally Posted by jagabo View Post
    previously 6 minutes took over 8hr, now 1 minute 30 minutes - i think that something is wrong with configuration of computer - i agree that P4 is not fastest CPU on the world however i assume that there is still room to improve - new HDD can be used later with newer computer, actions to release CPU and memory usage for sure improved performance already so why not try to do as much possible without buying new computer?
    At some point we achieve limitations that or will be accepted or a new computer must be serious option to consider.
    i forgot to mention - verify heat-sink on P4 - hot P4 start reduce clock and performance - poor cooling can be an issue too - quite common problem with older computers is poor heat-sink contact with CPU, lot of dust, sluggish fun - overheated P4 will be very slow.
  29. I don't use Premiere CS3 but I hear Adobe's video editors tend to be memory hogs. With 2 GB of DRAM and Windows XP I wouldn't expect this to be a problem, but virtual memory cache thrashing can bring even the fastest systems down to their knees (ie, 1/100 or less the normal speed). Look to see how much memory Premiere is using while encoding.
    Just as a reference point, I encoded a 1 minute, 1920x1080i30, MPEG 2 source with TMPGEnc Plus (one of the slowest MPEG 2 encoders I've used) with the output set to 1920x1080i, CBR 25000 kbps. At its slowest (highest qualitiy) settings it took about 20 minutes to encode the video. At its fastest (lowest quality) settings it took about 4 minutes. This was on a quad core Q6600 CPU but I had TMPGEnc set to use only one thread (Task Manager showed about 25 percent CPU usage while encoding). A single core of a 2.4 GHz Q6600 isn't hugely faster than a 3 GHz P4. Certainly not more than twice as fast. And I doubt Mainconcept's MPEG 2 encoder is much slower than TMPGEnc.
  30. Video Restorer lordsmurf's Avatar
    No. Not even close.
    A single core CPU is really quite weak for HD playback, and especially encoding.
    CS3 is a resource hog on an old system.
    On a modern system (2007 or newer, era of CS3), meaning dual or quad cores, 4GB+, it works nice.
    MainConcept is faster than TMPGEnc.
