I shot some video on a Nikon Coolpix on what I thought was the HD setting. About five out of 150 appear small, slow-motion and without sound. This sounds like the result of selecting the HS (High speed) setting, yet when I tested shooting video on this setting they did not appear like this.
Is it possible to retireve the audio and/or increase in size?
Hope you can help,
Martin
Do you have a short sample? Then post it in our forum or a filesharing site.
Hi Baldrick - thanks for the reply. I've uploaded a file here:http://www.nqwg.co.uk/swa/ETHIOPIA_DAY_5_081.MOV and I've uploaded it to this post.
thanks,
Martin -
The audio seems silent for the first 1:20 minutes. I tried extract it with some tools. But after 1:20 it plays fine, except the low video quality.
Thanks for that. What tools did you use? It seems strange that it played OK after 1.20. Have you any idea what it might be (or how I might make them work?)
thanks,
Martin -
making them bigger would only make them look worse. here are the specs.
Format : AVC
Format profile : Baseline@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=30
Codec ID : avc1
Duration : 4mn 16s
Bit rate : 629 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.273
Stream size : 19.2 MiB (77%)
you could use an editor to cut off the silent parts and render out the good parts. here's what it looks like on the editor timeline.
[Attachment 9621 - Click to enlarge]
and if cut and increased to 640x480.--
Slow motion videos- how to create some sections
By doggieusa in forum EditingReplies: 3Last Post: 10th Dec 2012, 19:42 -
Loading videos slow in IE
By tarsierspectral in forum Video Streaming DownloadingReplies: 10Last Post: 30th Jun 2011, 06:15 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Avisynth - Stack 4 Videos But Too Slow - Help!
By controlalt in forum EditingReplies: 10Last Post: 14th Mar 2011, 09:36 -
slow playback on 1080p videos with COREAVC
By mr-scarface in forum Software PlayingReplies: 40Last Post: 9th Jan 2009, 08:00
